Old 02-29-2020, 08:20 PM   #1
Doug Black
Default Flathead Head bolt threaded holes for head
Would anyone have, or know how I can get
The hole locations both
X and Y, for a 24 stud flathead motor.
THANKS
Doug Black is offline   Reply With Quote
Old 02-29-2020, 08:38 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Flathead Head bolt threaded holes for head
A simple head gasket should suffice, no? I can't think of a source offhand for that particular info! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-29-2020, 08:51 PM   #3
JSeery
JSeery's Avatar
There have been post in the past of CAD/CAM type data/layouts. But I have no idea where or when they were posted. Or if they were even correct.
Old 02-29-2020, 09:13 PM   #4
oldford2
oldford2's Avatar
THANKS
Doug, Why are you asking? What are you trying to do?
John
oldford2 is offline   Reply With Quote
Old 02-29-2020, 09:15 PM   #5
JSeery
JSeery's Avatar
The Ford engineering drawings might have the information your after.
Old 03-01-2020, 06:24 AM   #6
JWL
I think I remember giving that info to Lawrie when he was making cylinder "o"rings. Perhaps he will still have it available and will speak up. The Ford drawings are dimensioned in a manner which requires some calculations for each stud location.
JWL is offline   Reply With Quote
Old 03-01-2020, 07:46 AM   #7
Jack E/NJ
Jack E/NJ's Avatar
https://www.fordbarn.com/forum/showp...9&postcount=29
Jack E/NJ
