Old 01-26-2022, 11:26 AM   #1
RickMcK
Default 36 PU-After market muffler?
I'm looking for a after market muffler for my 36 pick up. I don't want to pay $350, for a Ford script reproduction. Does anyone know if there is a generic one that will interface with the existing stock exhaust system?
Sent from my LM-V405 using Tapatalk
Thanks
Rick McKenney
Seattle WA
RickMcK is offline   Reply With Quote
Old 01-26-2022, 04:35 PM   #2
Kube
Kube's Avatar
Default Re: 36 PU-After market muffler?
Rick, If you have the old muffler, take it to NAPA. Ask for a counter person that can think beyond a computer screen. There are books there that depict every muffler they sell. Each has every dimension listed.
There are also after-market places that can supply you. Waldron's comes to mind.
Old 01-26-2022, 04:52 PM   #3
Clem Clement
Clem Clement's Avatar
Walker made one for my 40 merc. I got it from the Fordbarn wanted site.
Clem Clement is offline   Reply With Quote
Old 01-26-2022, 08:32 PM   #4
36coupe
36coupe's Avatar
You can also search muffler on Rock Auto and pick a muffler by inlet size from 1.65” to 4”
36coupe is offline   Reply With Quote
Old 01-26-2022, 09:41 PM   #5
51504bat
51504bat's Avatar
No old time muffler shops in Seattle? Should be easy peasy for them to adapt one for your p/u.
Old 01-26-2022, 09:47 PM   #6
Rodrelic
I got mine from tractor supply, by dimension. I used 2
Rodrelic is offline   Reply With Quote
Old 01-26-2022, 10:35 PM   #7
alanwoodieman
tractor supply~!!!
alanwoodieman is offline   Reply With Quote
Old 01-26-2022, 11:14 PM   #8
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
I used a Walker 18179 on my otherwise stock '36 pickup exhaust system (stock 221 cu in poured bearing motor), went on with minimal fiddling (cut a little bit off the tailpipe side to just leave a straight stub, and cut off a small unused bracket) -cost about $45
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 01-27-2022, 09:35 AM   #9
RickMcK
Adam. Thanks for the walker part #. I will verify the input and output pipe diameters and order one, if it's correct, otherwise I will make a trip to NAPA.
Thanks
Rick McKenney
Seattle WA
Old 01-27-2022, 09:56 AM   #10
Don Rogers
Don Rogers's Avatar
Rick, This drawing of original muffler might help you.
Don Rogers is offline   Reply With Quote
Old 01-27-2022, 10:34 AM   #11
RickMcK
Don. thank you. This is exactly what I need to talk to the folks at NAPA.
Thanks
Rick McKenney
Seattle WA
