01-24-2022, 09:50 AM | #1 |
Video of flathead build and dyno test
https://www.powernationtv.com/episod...tty-3-deuce-v8
Interesting video where they built what I would consider a high dollar flat head and put it on a Dyno. I would’ve thought they would’ve got a bit more horsepower. They didn’t measure squish in the video. I wonder if they skipped some of the detailed steps? |
01-24-2022, 10:02 AM | #2 |
Re: Video of flathead build and dyno test
This build has been on here a couple of times already. Thanks
01-24-2022, 10:32 AM | #3 |
It actually should be titled : "How to spend the most money building a flathead".
I'll reserve comment on the rest. |
01-24-2022, 12:39 PM | #4 |
This is also a perfect example showing that those guys we've all run into at the local "Tasty Freeze" hot rod get-together with those 200 and 250 horsepower flatheads are full of "it"! DD . |
01-24-2022, 09:45 PM | #5 |
Amen.
01-25-2022, 11:27 AM | #6 |
01-25-2022, 04:43 PM | #7 |
What would a 53 mercury engine dyno at? The factory called it 125hp. How did ford measure it?
01-25-2022, 11:59 PM | #8 |
250 hp has been done many times but not with 3 carbs and a "3/4" cam.
I didn't even watch the video and that made me giggle. |
01-26-2022, 02:10 AM | #9 | |
Yeah, that's them! That's them guys at the "Tasty Freeze". They must'a been pretty powerful, 'cuz them right rear tires was smokin' like a train when they peeled-out! DD . |
01-26-2022, 10:25 AM | #10 |
01-26-2022, 06:32 PM | #11 |
In JWL's book, he got 79. 6 on a 239. Never got over 100 until he installed a cam. Had one of my 276/L-100 engines back in the 90s At 135 hp@4800. Not bad??
01-26-2022, 08:49 PM | #12 |
I know of one stock block 292 cube Ford flathead {intake and exhaust ports located in original location} normally aspirated that's over 200 HP using one four barrel carb burning gasoline. However it is expensive ones weekly allowance needs to be rather high to afford such a powerhouse.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
