Old 01-22-2022, 10:21 PM   #81
mercman from oz
mercman from oz's Avatar
Default Re: 1956 lincoln premiere
I think that this 1956 Lincoln Premiers Coupe is RED?
Old 01-22-2022, 10:46 PM   #82
dmsfrr
dmsfrr's Avatar
Originally Posted by 56yblock View Post
hello everybody, i looking for parts for my 1956 lincoln premiere turbo drive or mercomatic medium case automatic transmission:
the pinion carrier and the park pawl,
does anyone knows where i can find them? look at the pics,
thanks for help me
With one phone call to Vanpelt Sales I located some limited production parts for rebuilding a '57 transmission that the local old-school transmission shop spent 3 months looking for and couldn't find.
http://www.vanpeltsales.com/
Originally Posted by Daves55Sedan View Post
Try Northwest Transmission Parts. They may have hard parts you need, but they will likely be pricey.
Just because, their website... http://www.nwtparts.com/
dmsfrr is offline   Reply With Quote
Old 01-23-2022, 02:43 AM   #83
56yblock
56yblock's Avatar
thanks guys for help me, i've send a message at them...
56yblock is offline   Reply With Quote
Old 01-23-2022, 02:46 AM   #84
56yblock
56yblock's Avatar
yes i think too it's red
Old 01-23-2022, 10:44 AM   #85
56yblock
56yblock's Avatar
what kind of transmission automatic oil i must to use after rebuild it?
Old 01-23-2022, 02:07 PM   #86
dmsfrr
dmsfrr's Avatar
Are you doing the rebuild, or a transmission shop?
If a shop is doing the work and they're giving you any kind of warranty, ask them so you don't void the warranty.
If you're doing the work ask the place that's supplying the parts, in case there is a compatibility problem.
The shop that rebuilt the Fordomatic in my '55 said to use Mercon transmission fluid.
It's the most chemically similar to the original Type A, which was discontinued decades ago.
Old 01-24-2022, 01:35 AM   #87
KULTULZ
KULTULZ's Avatar
Post Re: 1956 lincoln premiere
The OP is in France so any recommendation they will give will most likely be an EURO lubricant.
MERCON V is the correct fill here.
KULTULZ is offline   Reply With Quote
Old 01-24-2022, 11:05 AM   #88
delco1946
delco1946's Avatar
Based on my experience having a shop rebuild my tranny, I would not ask for their opinion. The warranty is the least of your problems if it starts to damage itself. Tell them firmly that it should be Dex/Merc as stated previously, unless they have replaced the bronze plates etc. Shops don't rebuild fordomatics these days so unless they're truly a specialty shop, theyre out of their element. They also wont bother to open the manual. Rather they'll treat it like "other automatics" (bad move) and be inclined to use Type F cuz F = Ford or 1940s style hydraulic oil.
delco1946 is offline   Reply With Quote
Old 02-01-2022, 01:45 AM   #89
56yblock
56yblock's Avatar
hello guys, i received my rebuild kit with parts, they recommanded the mineral oil but synthetic works also, cause there's a new composantes parts in..
Old 02-01-2022, 03:48 AM   #90
KULTULZ
KULTULZ's Avatar
Exclamation Re: 1956 lincoln premiere
... they recommanded the mineral oil but synthetic works also ...
MINERAL OIL ... ?
That was used in MT of the period and has been upgraded several times since then.
Look for EURO that has the same SPEC NO. (if there is one). CASTROL should offer it.
EDIT -
GO HERE - https://www.castrol.com/en_us/united...nsmax-dex-merc
.. and discuss with the re-builder. I would think it is available in FRANCE.
HERE - https://www.castrol.com/en_us/united...nsmax-mercon-v
... is their MERCON-V equivalent.
Old 02-02-2022, 03:51 PM   #91
56yblock
56yblock's Avatar
i found this one.. mineral oil
Old 02-02-2022, 06:03 PM   #92
KULTULZ
KULTULZ's Avatar
Arrow Re: 1956 lincoln premiere
Talk it over with the re-builder and see what his reaction is -
DEXRON History - https://en.wikipedia.org/wiki/DEXRON...93_DEXRON-II(D)
Old 03-21-2022, 01:38 PM   #93
56yblock
56yblock's Avatar
hello guys,
shes back home with total rebuild automatic transmission ...it works like a new...
Old 03-21-2022, 01:49 PM   #94
Dobie Gillis
Dobie Gillis's Avatar
Wow, that's great! Glad you got it fixed. I'm very jealous...
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
