Old 04-29-2021, 09:20 AM   #21
ct1932ford
ct1932ford's Avatar
Default Re: Pertronix Nightmare
Have been running Pertronix for nine years in my roadster. Runs like a swiss clock.
Working on a new coupe now with some running issues I have not solved yet. I need Ronnieroadster! It may be next!
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 04-29-2021, 01:22 PM   #22
Ronnieroadster
Ronnieroadster's Avatar
A road trip in the future with the ARDUN powered service car looking forward to it. See you Sunday at the swap meet.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 04-29-2021, 01:22 PM   #23
1931 flamingo
1931 flamingo's Avatar
Ronnie's the man ! ! !
Paul in CT
Old 04-29-2021, 05:39 PM   #24
Tim Ayers
Paul in CT
That he is.
Old 05-01-2021, 10:43 PM   #25
fordor41
fordor41's Avatar
I had Pertronix in my '41 forever. after a valve job it idled like crap. thought it was ignition
I had a spare pertronix and swapped it out and nothing. went back to my original and ok but lousy idle. contacted pertronix and they said send them back. a week or so later I received 2 new ignitor 1's. turns out my coil was way out of range for their ignition. I think my coil slowly went south but not enough to mess up the ignition but when I installed the spare it immediately burned out. other than that I've had great luck with Pertronix. FYI, the problem was a $7 PCV!
fordor41 is offline   Reply With Quote
Old 05-01-2021, 10:47 PM   #26
tubman
tubman's Avatar
PCV valve? I thought it was the coil. Please clarify.
Old 05-02-2021, 10:06 PM   #27
fordor41
fordor41's Avatar
my crappy PVC gave me a bad idle. after I installed the new Pertronix ignition with a good coil, idle was still bad. then I discovered the PCV was bad. BTW, SBF in my '41.
Old 05-02-2021, 10:24 PM   #28
tubman
tubman's Avatar
Wow! Interesting; I never heard of anything like that. It's good to know that a bad PCV valve can cause this kind of problem.
Old 05-03-2021, 10:03 PM   #29
fordor41
fordor41's Avatar
I'll try again. had a valve job done and engine ran good on the street but idled terrible. Changed plugs, wires, dist, carb, disconnected all vac from engine and still no good. That's when I changed the Pertronix ign. and ended up with a bad coil/ign. after getting ign and coil straight I discovered PCV was stuck in open
position. After changing the PCV, idle smoothed out, vac jumped up and got rid of "popping" out the exhaust
Old 05-03-2021, 10:20 PM   #30
tubman
tubman's Avatar
Thanks for the explanation; you learn something new everyday.
Old 05-04-2021, 09:33 AM   #31
JMFL36
JMFL36's Avatar
I recently converted my '54 Mercury 6V positive ground car to PerTronix ignition and coil. Car is now much easier to start and runs great.
Document your car with CollectorCarCompanion
JMFL36 is offline   Reply With Quote
Old 05-04-2021, 09:52 AM   #32
flatjack9
flatjack9's Avatar
The pintle in the PCV must have been stuck or gone. It's supposed to limit flow at idle.
Old 05-04-2021, 10:55 PM   #33
fordor41
fordor41's Avatar
What ever was wrong, a new PCV solved my problem. Don't always believe if you shake a PCV and it rattles it is OK. My PCV rattled but was either in open position or close to open so my vac was low but steady. That's why I concentrated on anything that would effect all cylinders, to cause the low vac condition
Old 05-05-2021, 08:28 AM   #34
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
A flathead requires a "balanced" ignition system . Correct distributor , point, condensor cap rotor and ignition cables .
One wrong part and the system will fail . ( usually a incorrect ignition coil) do some reasearch and then use the best you can buy and it will work forever !!!!!
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 05-05-2021, 04:21 PM   #35
backrodebob
backrodebob's Avatar
coil primary 1.6 secondary 11.2
backrodebob is offline   Reply With Quote
Old 05-05-2021, 04:25 PM   #36
backrodebob
I replaced that 3 mo. ago
Old 12-21-2021, 01:38 AM   #37
Lawrie
Lawrie's Avatar
This is a long shoot, I have asked petronox if the unit will trigger an MSD street fire unit , they said yes it will ,so have worded one.
Has any one done this, and its not for the 33 or 34 its for a customers rod.
Lawrie
Lawrie is offline   Reply With Quote
Old 12-21-2021, 04:06 AM   #38
aussie merc
aussie merc's Avatar
just curious if you run an alternator or generator Mallory use to supply a little red box called a power cell they said fitment was optional on alternator but mandatory with generator due to the fact that gen voltage regs are mechanical and therefore create micro spikes when they work and their electronics don't like it
aussie merc is offline   Reply With Quote
Old 12-21-2021, 06:45 AM   #39
Lawrie
Lawrie's Avatar
Car has an alternator fitted and is 12 v
Lawrie
Old 12-21-2021, 06:55 AM   #40
koates
backrodebob, you state that your coil primary resistance is 1.6 ohms. In that case it should be used with a 1.5 ohm ballast resistor in series with the coil primary winding. Without the ballast resistor your coil primary current draw would be about 8 amps which is way to high for your Pertronix unit to handle and it is blowing up. The coil primary current draw should be only about 3 or 4 amps. Very important to understand how all these components work together. YOU CANT JUST GUESS HERE, EVERYTHING HAS TO BE CORRECT. I have had several pertronix units working in cars for over 30 years. Regards, Kevin.
koates is online now   Reply With Quote
