01-04-2022, 04:32 PM | #21 | |
Re: Tools/supplies needed while traveling
You'll end up with more wear and tear on your carb carrying it under the seat than you will on the engine. |
01-09-2022, 03:01 AM | #22 |
I carry these goodies. I send this list to all on the tour. It gives members confidence parts are at hand. Especially the clutch release arm and the accelerator return spring
MODEL A TOOL KIT FRONT TOOL BOX Wooden cheese box Clothes pins Distributor wrench Door hinge pin Fuses-30 Amp Goop/duct and elect. tape Ignition Switch bypass Misc. wrenches/Feeler gauge/screw drivers Muffler seal Point file Short Phillips screwdriver for timing Spark plug wires Tire weights Tube repair kit Wire Bendix spring Carburetor Clutch release arm Coils-2 + wires Compression gauge Cut out Switch-2 Distributor drive gear and spring Exhaust Clamp and gasket Fan Belt Float adjustment tool Funnel Gallon of H2O (on running board) Gas cap Gasket seal Grease gun Glue Ignition harness cork and nail (replaces bad switch) Instant Beer JB weld Leather belt (Bearing replacement) Oil Misc. nuts, bolts and washers Multimeter Polish Rags Rod bearing cap Rubber gloves Spritzer Starter switch Timing Gear (socket and tool in tool bag) Voltmeter Water pump and gasket Water pump grease Wheel bearings-2 sets Wheel bearing Grease PACKAGE TRAY Batteries Business cards Bratton’s catalogue Flashlight Fire Extinguisher (on running board) First aid kit Good luck charms Hand wipes Light bulb box Model A club Roster (in door pocket) Repair manual Snacks Walkie talkies Work gloves UNDER SEAT Plastic Parts Box Accelerator return spring Ammeter-2 Axle key and shims Axle nut remover Carb gasket set plus needle valves Condenser and Points Gas filter screen and glass gasket Generator brushes Distributor cam and cap and bottom plate Engine bearing shims Light Bulbs Plug wires Rotor Spark plugs Speedo gear Starter Bendix bolts Water pump packing Wire ties Valve and guide Cotter pins Crank Distributor body Fan belt Gas gauge repair kit and tools Small hyd. Jack with base Lug wrench 8x10 Glossy of Sandy Stethoscope Tire tube Tow rope RUMBLE AREA American flags Blanket Bungees Calico chicken Chock Flares Folding chairs (sometimes) Generator (No) Head gasket Paper towels Poncho Torque wrench Tool bag |
01-10-2022, 08:44 PM | #23 |
Now, THAT is being prepared ^^^^^
eog |
01-10-2022, 10:07 PM | #24 |
Clem, I like your list a lot but I can't fathom the purpose of a short phillips screwdriver for timing. Is that for some newfangled ignition system?
And is the Gallon of H2O (on running board) to ensure the "Instant Beer" gets reconstituted properly? A speedometer gear isn't a bad idea but given that I have had 2 speedo cables give out and I'm still driving the A without a speedometer 3 years later, I don't know that I would bother carrying that particular part. |
01-14-2022, 05:41 AM | #25 |
The short Phillips screw driver with the regular size grip and short shaft goes in the timing pin hole perfectly. Try it. It is much easier to find the dimple in the timing gear than use to original timing pin. (don't forget to replace the pin after use!)
All this gives other tour members confidence that we can fix everything. Instant beer, when applied properly, is most helpful. Don't forget a rubber chicken, mechanical rat, and spring snake to liven things up. I also have a huge heavy machine wrench, when dropped will bring members a-running to see... I was maintenance tent chair for 2 national meets in the Norfolk, VA area. We learned a lot and had so much fun fixing stuff. Anyone else there?? Clem |
01-25-2022, 07:31 AM | #26 |
https://www.youtube.com/watch?v=h-L6F4PHlOs |
