02-13-2021, 10:24 AM | #1 |
Gas Adjusting Valve Seat
I am rebuilding a carburetor for a spare. After disassembling the carb I soaked it cleaner and hosed it out. It looks like a good core. Looking down the bore into the GAV I see where the casting bottoms out and there are four tiny holes in the casting that would lead into the cavity going to the carb bowl. Is this a carb that has the removeable seat and I am seeing how casting looks on the other side of the removeable seat? Thanks for your help, Ed
02-13-2021, 11:27 AM | #2 |
Re: Gas Adjusting Valve Seat
Should be one hole for the gav to seat, may be looking at some dirt and appears to be four holes? If removable it will be a brass fitting with gasket,looks like a comp jet. some carbs do not have brass fitting but still have a tapper
www.whidbeymodelaclub.com Last edited by Gary WA; 02-13-2021 at 11:48 AM. |
02-13-2021, 11:46 AM | #3 |
www.whidbeymodelaclub.com Last edited by Gary WA; 02-13-2021 at 07:21 PM. |
