05-09-2019, 07:04 PM | #21 |
Re: Oil Pan Dipstick Mount Repair
Hi Joe, below here's a shot of how your dipstick adapter will end up being fastened to the pan!
When we tested it for leaks the only issue was a slight leak from the bolt threads showing up as a drip from under the bolt heads. We resolved it by lightly "spotfacing" the adapter and using very small copper washers under the bolts. Using sealer on the bolt threads would accomplish the same result but we wanted no leaks without any sealer in play! Looks like a done-deal! Thanks, Gary in N.Y. P.S. Got the Navarro's today, not exactly my choice for high-quality heads but "it is what it is". We'll deal with them and make them work, I'll call you on the weekend and explain! Have some pictures for you.
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 05-09-2019 at 09:04 PM. |
05-10-2019, 07:21 AM | #22 | |
Curious what you found wrong or not optimal with the Navarro heads? I bought a set from Barney directly in '92 and have been holding them to use on my father's '32 Tudor sedan. I'd love to hear your thoughts on them |
05-10-2019, 07:26 AM | #23 |
Been seeking a replacement dipstick tube boss. Seems like all suppliers are presently out of stock? Any suggestions as my one is worn in the internal thread.
Phil NZ |
05-10-2019, 08:21 AM | #24 | |
Never tried to fix one but looks doable?? When we dropped Joe's pan by my friend the welder he tried to talk me into letting him make an entirely new 1-pc adapter from steel and weld it straight to the pan. Guarantying absolutely no chance of a leak and no fasteners OR gaskets needed any longer! I told him I didn't feel we needed to go that far, he claimed it would be real easy for him to do and still not that expensive! Thanks, Gary in N.Y. P.S. Hi Tim, with respect to the Navarro's, can't say about any of the older castings but these new ones definitely could have used much more care during the final machining! The ones I have here are not really what I expected to see with today's improved machining and casting techniques! I'll have more info on them a bit later in the month, will start a separate post!!
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 05-10-2019 at 08:24 AM. Reason: Add |
05-10-2019, 08:24 AM | #25 | |
Thank you! I'd be interested to hear what you found. I've heard the same about the new Navarro intakes. |
05-13-2019, 03:17 PM | #26 |
05-13-2019, 08:46 PM | #27 |
Drilled rivet heads off on an off-topic flathead. Punched rivet remains into pan. Slathered mount in silicone. Sheet-metal screwed it back on. 8^) Jack E/NJ
Thread Tools | |
Display Modes | |
