Old 07-01-2020, 07:06 PM   #1
stewgee
stewgee's Avatar
Cool 600w oil
I stopped by O'Reilly the other day and asked the guys if they had any 600 weight oil. They asked me what I had been smoking. Crazy huh?
stewgee is offline   Reply With Quote
Old 07-01-2020, 07:27 PM   #2
Ruth
Default Re: 600w oil
Well ya see, 600w oil isn't 600 weight. Some use SAE 140. I use SAE 250 as I believe it is closer to 600W.
You been smokin' fan belts again?
Ruth
Old 07-01-2020, 09:21 PM   #3
stewgee
stewgee's Avatar
Yeah Ruth being a newbie to the Mod A world I just never crossed this. Always worked with the 10w`s and so forth. Thanks for the lesson.
Old 07-01-2020, 09:32 PM   #4
redmodelt
redmodelt's Avatar
If you really want to mess with them ask for steam cylinder oil! LOL
Old 07-01-2020, 09:37 PM   #5
stewgee
stewgee's Avatar
Old 07-01-2020, 09:51 PM   #6
Terry, NJ
Terry, NJ's Avatar
Don't ignore homegrown variations of STP. I won't use it straight, but as a concoction with other thick gear oils. The rear end does not need 600. The transmission does! Why? you ask.
To slow the gears down quickly when shifting and to prevent leaking. The rear doest need to slow down because there is constant mesh. On your steering box, you'll note two bolts, one is a pipe threaded filler plug. The other is an adjustment for the bearings in your steering box. Do n't tighten this one too much, just snug it. No tightening it! It snugs a race up against a bearing and too tight cracks it and you'll have a click in your steering wheel as you turn it. Remove the drain plug and check the fluid. Normally, this also takes 600. However some of us have found that John Deere , Cornhead Grease works very well. It's cheap ($3-4 a tube) and it's pretty available and it doesn't leak out. So there, you have plenty to work with. Good Luck!
Terry
Old 07-01-2020, 10:49 PM   #7
Ruth
Terry
Drain Plug? On the steering box? I wasn't aware it had one.
Ruth
Old 07-01-2020, 10:58 PM   #8
RonC
RonC's Avatar
https://www.kellerheartt.com/product...19399813070959
RonC is offline   Reply With Quote
Old 07-01-2020, 11:07 PM   #9
PalAl
PalAl's Avatar
http://penriteoil.com.au/
Very good steering gearbox oil/grease
PalAl is offline   Reply With Quote
Old 07-01-2020, 11:57 PM   #10
Kurt in NJ
Kurt in NJ's Avatar
600W is steam cylinder oil,for steam engine use, also listed for use in worm drive gearboxes
Then there is the 600 series of gear oils, listed for use with spur gears, and bevel gears.
I got a pail of Shell omala 680 for my car
Kurt in NJ is online now   Reply With Quote
Old 07-02-2020, 05:46 AM   #11
springerpete
springerpete's Avatar
Just yesterday I got a gallon of MOBIL 600 W. From a guy here in Maine. He bought a 5 gallon pail from the distributor for $135. $6.75/qt, pretty nice.
springerpete is offline   Reply With Quote
Old 07-02-2020, 06:04 AM   #12
Patrick L.
Patrick L.'s Avatar
600W is in the 180-240 weight range. Either 140 or 250 work just fine.
STP is not a lubricant, many use it though.
The transmission oil is also used in the rear end and steering box.
Old 07-02-2020, 07:17 AM   #13
ryanheacox
ryanheacox's Avatar
I also think it's important for the transmission oil to be tacky and cling to the gears. I've got an old bottle of 600W from the company that eventually became Macs (Specialty Auto Products I think). Anyway, it is very dark, very thick and it STICKS to everything.
The last 600W I got from Macs a few years ago had the same label explaining what 600W was on the bottle but this stuff is just SAE140 gear oil, thick and slick but no cling whatsoever. I use it in the rear end, works well there.
I like the 600W from Brattons, it is also dark, not as tacky as the old stuff but not bad.
Old 07-02-2020, 07:19 AM   #14
WHN
Terry
I could have written the above. We use 50/50 mix STP and 600w oil from MAC’S in transmission and rear end. Cornhead grease In steering box and u-joint.
Enjoy.
Old 07-02-2020, 10:10 AM   #15
Licensed to kill
Licensed to kill's Avatar
The "W" in oil designations is for "winter" not "Weight". I use Chevron Maropa 680 in my gear boxes, corn head grease in steering boxes.
Licensed to kill is offline   Reply With Quote
Old 07-02-2020, 11:38 AM   #16
Patrick L.
Patrick L.'s Avatar
Thats kinda misleading. W stands for weight, but, the W meaning winter means that the number before the W such as a 10 means the oil flows like a 10 weight oil when cold. The number after the W such as 30 means the oil has the film strength of a 30 weight.
Its the same oil viscosity.
Old 07-02-2020, 11:42 AM   #17
Patrick L.
Patrick L.'s Avatar
Its been mentioned several times here that the 600W from some of the vendors is 140 or 250 with STP added. I don't know if its true or not.
There are other oil suppliers that sell 140 and 250. Either will work fine. I see little difference between them.
Old 07-02-2020, 04:21 PM   #18
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I have been using a 680 oil (CHEVRON OR MOBIL) in my steering box, transmission, and differential for many years. I find it to be outstanding........
Dick M is offline   Reply With Quote
Old 07-02-2020, 07:46 PM   #19
Patrick L.
Patrick L.'s Avatar
If I remember correctly Mobil/Chevron 680 is an SAE 140 viscosity oil.
Old 07-02-2020, 08:16 PM   #20
marc hildebrant
marc hildebrant's Avatar
Best to buy the correct product from the Model A suppliers. Mine came from Berts.
I would not want to mix up something and hope that its correct when the suppliers have the correct stuff.
Marc
marc hildebrant is offline   Reply With Quote
