Old 08-26-2021, 06:55 PM   #1
Pech33
Default What year is my engine?
VanPelt says a 1939-42 block has three openings between the center cylinder bores, top one is triangular and the two lower ones are trapazoids. A 45-48 block has the top one triangular and the two lower are round holes. This block has a triangle on top, circle in the middle and trapzoid at the bottom. Any help?
Pech33 is offline   Reply With Quote
Old 08-26-2021, 07:31 PM   #2
Will D
Will D's Avatar
Default Re: What year is my engine?
Looks like a Canadian made C59A.
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 08-26-2021, 11:41 PM   #3
Pech33
Thanks. Do we have a date range that it might be? I’ll take a look for that casting location.
Old 08-27-2021, 04:27 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
The "59" indicates 1946-'48 production. DD
Click Links Below
T5 W/TORQUE TUBE
Old 08-27-2021, 05:58 AM   #5
richard crow
the crab dist says it,s a 1942 eng . if the dist is the is the oriignal one
richard crow is offline   Reply With Quote
Old 08-27-2021, 07:18 AM   #6
rotorwrench
rotorwrench's Avatar
Canadian engines will have the casting number with C prefix. Prewar 95 hp 239 blocks and wartime 239 blocks have the same deck configuration. There are casting differences between the early 39 thru 40 239 blocks and 41 thru wartime 239 blocks. If it's a truck engine then it will likely be a relieved type block.
Canadian early 239 blocks have a little 99 casting number on the front right if I remember right. US made early 239 blocks were stamped 99 on the front right intake deck. All pre 1941 engines have sand clean out ports on the pan rails. 1941 & later have no clean out ports and have what appears to be a raised intake deck.
rotorwrench is online now   Reply With Quote
Old 08-27-2021, 08:14 AM   #7
Bored&Stroked
Bored&Stroked's Avatar
My guess is that it is a 39-42 239 CI engine - given the round center hole. Does it have the core-sand cleanout plugs on the pan-rail and a "raised" intake deck surface? Take it a bit further apart, clean it up a bit and we'll be able to tell you more. I have a very similar engine in my 32 Cabriolet.
Thread Tools
Display Modes
