Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 01-14-2020, 05:58 PM   #1
Rance29
Default Early 5 lug type RH wheels for sale
This may not be the correct place to post this. If not, I apologize. I have three early 1.5 ton Ford truck wheels that are surplus to my needs. All three have 7.50-20" tires mounted on them. One has a 3" offset (from edge of riveted center to outside of fixed flange), one 3.5" offset and one 4" offset. These are the snap ring type with a solid ring and not the center split "Widow Makers". They all look to be in good shape and I believe usable and safe. $30 each. Wheels are located in Joseph Oregon.
Rance29 is offline   Reply With Quote
Old 01-14-2020, 07:54 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Early 5 lug type RH wheels for sale
Your ad needs to be in the classifieds for the year the parts fit. Few people will even see it here. There may be someone out there that can tell you what year they fit if you do not know. I suggest posting on the Model A or Early V8 forum with photos and ask. Then once you find out, post your ad in the proper section. Model A, Early V8 or Late V8
