Old 06-21-2021, 01:24 PM   #1
Supertuner700
Default 1938 85 1.5 ton hand start crank
My 1.5 ton has the provision on the end of the crankshaft for a hand crank. Did these trucks come with them? Anyone have one? Mine looks like its missing the support on the bottom of the core support for the crank also.
Supertuner700 is offline   Reply With Quote
Old 06-21-2021, 04:29 PM   #2
Bob C
Default Re: 1938 85 1.5 ton hand start crank
BB-17036-B Crank (starting), 51A-19040 Extension (starting crank).
Old 06-21-2021, 07:41 PM   #3
Supertuner700
Thanks Bob
Old 06-24-2021, 07:26 PM   #4
KDL
KDL's Avatar
My 35 has what I believe is a crank support that flips up from behind the bumper. I don't have a crank.
KDL is offline   Reply With Quote
Old 06-24-2021, 08:39 PM   #5
Supertuner700
KDL can you shoot a picture?
Old 06-24-2021, 10:21 PM   #6
expavr
expavr's Avatar
I'm not sure what you're looking for regarding the structure of the access holes thru the radiator and grille shell for the hand crank, but the attached photos of those access holes on my 1940 Ford Tonner show the holes and the metal bracket in the radiator that would have been used to help support the hand crank. The finished product photos give a better picture of how they look. I had the radiator rebuilt using all the OEM brackets and same core size and dimensions. Hope this helps.
expavr is offline   Reply With Quote
Old 06-25-2021, 06:00 AM   #7
KDL
KDL's Avatar
I'm away from the truck for a few days. I'll try to post a pic when I get back.
Old 06-25-2021, 01:51 PM   #8
Supertuner700
Ah, thank you. Mine is much different. Mine goes below the radiator and I think my bracket would mount to the bottom of my radiator but my bracket is missing.
Old 06-25-2021, 01:51 PM   #9
Supertuner700
Thank you
Old 06-25-2021, 03:11 PM   #10
Clem Clement
Clem Clement's Avatar
I have a crank with my 39 pickup. Aftermarket radiator so does not have rad hole. Long shaft. fits 40 Woody.,
Clem
Old 06-25-2021, 06:10 PM   #11
Supertuner700
Mind shooting me a picture? I think it would be a cool add for my old truck.
Clem
Old 06-25-2021, 07:23 PM   #12
Supertuner700
Picture from the bottom of the truck bottom of radiator and hand crank snout on the crank pulley. Looks to me like a support is missing from the bottom of the radiator
Other picture is grill crank hole
