Old 06-05-2021, 05:40 PM   #1
Deadforty
Default '40 Gas, Oil pressure Gauges
Well, I finally got the "40 running again !! Now, I'm trying to tie up loose ends. How do you check to see whether or not your gauges are not working? I did the CVR route and only the Temp and Volt gauge is working. I mistakenly installed a 80lb oil pressure sender, using a 40lb pump. Can this be remedied by changing senders? Also, I might add that the gas and oil pressure were registering, but suddenly quit while driving down the road. I don't know what to check or do at this point.
P.S.
This site has been a great source of information in this rebuild! A lot of good people with similar interests !!!!
Deadforty is offline   Reply With Quote
Old 06-05-2021, 06:30 PM   #2
Rodrelic
Default Re: '40 Gas, Oil pressure Gauges
I like the old school gauges but temp gauge repair sounds tough so I am trying SW with electro first time. Can’t easily find lower temp 0-200 deg old timely that really work anymore. But for oil so easy to use tube/hose and any gauge. For fuel pressure, I understand it’s hard to find 0-10 # gauge for normal flathead feed.
Rodrelic is offline   Reply With Quote
Old 06-05-2021, 10:19 PM   #3
JSeery
JSeery's Avatar
The gauges work by providing 6v to the gauge. The gauge is then connected to the sensor, which acts like a variable ground. If two gauges stop working, I would guess the issues is at the power input to the gauges.
The gauge needs to be matched to the sending unit for oil pressure.
Old 06-06-2021, 05:48 AM   #4
fortyfords
fortyfords's Avatar
I have not been able to find a 40 lb. oil pressure sender. I put a direct reading gauge on my 40 so now I know that my gauge reads half of what the pressure is. I can live with that
fortyfords is offline   Reply With Quote
Old 06-06-2021, 06:21 AM   #5
big job
big job's Avatar
Correct me; I haven't yet heard of a 40# sender or oil pump? It has always been
a 50# or 80# sender= look at your oil gauge if it has 30 in the middle its 80# If its a
lower number which I forgot will be 50# sender..
big job is offline   Reply With Quote
Old 06-06-2021, 08:25 PM   #6
Deadforty
Sorry fella's, I installed a 80lb sender with a 50lb pump. Can changing the sending unit to a 50lb one fix this problem ? I also used "19Fordy"s diagram with a Ron Fransis CRV-1 reducer for the voltage drop. That replaced one of the "chopper" drop that I had installed a number of years ago. Now I'm wondering if I had the "chopper" one installed incorrectly and damaged the gauges. Also, the "chopper" was installed when the fuel and oil quit working.
Again, thanks for the input.
Old 06-06-2021, 08:36 PM   #7
JSeery
JSeery's Avatar
So, I'm assuming your converted to 12v? Second question, what oil pressures are you seeing? What engine are we dealing with? The pump rated pressure doesn't mean much, the pressure relief determines the system pressure. The pump rating is more about volume.
Old 06-08-2021, 07:49 PM   #8
Deadforty
Yes, I converted to 12V many years ago before this last rebuild. I am seeing 0 oil pressure on the gauge at this time, which was working when we started the engine up(the gas gauge was working too). The engine is an 8BA bored .040 over, Isky Max-1 cam, running 2 Stromberg 97's on an Offy Super dual intake with Red's headers. When we built the engine, I installed a 50LB pump.
Old 06-08-2021, 07:55 PM   #9
tubman
tubman's Avatar
Could I ask your rationale behind putting an early (50 lb) pump in an 8BA? Usually, it's the other way around.
Old 06-09-2021, 06:36 PM   #10
Deadforty
Tubman,
I think my rationale came from this site, in that I was not building a high performance engine and did need the high volume oil pump.
Old 06-11-2021, 05:37 AM   #11
Terry,OH
Terry,OH's Avatar
A 80# pump is the standard pump in the 8BA.
Old 06-11-2021, 03:53 PM   #12
Deadforty
Terry,Oh, and others;
I purchased the pump from Speedway. It was a Melling M19 Std volume oil pump. I figured I did not need a high volume, high pressure pump since I was only building a "warmed" street engine. I guess in my great ignorance of flatheads I chose the wrong pump. Right now, I'm really looking for answers and help to my questions about the gauges, otherwise, I'll just replace the original panel with something that all the gauges will work.
Thanks in advance to all helpful suggestions thus far. I'm checking them out.
Old 06-11-2021, 05:02 PM   #13
JSeery
JSeery's Avatar
As long as you have the correct pick-up for the pump and the screen is the correct distance from the oil pan, it should be fine.
Did you see the attachment to post #3 on how to check the gauges? Is there a different question you are asking? Maybe I'm not understanding what you question is.
Old 06-11-2021, 05:09 PM   #14
cadillac512
cadillac512's Avatar
Yes, changing to a 50# sender that matches your gauge will work just fine.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 06-11-2021, 06:10 PM   #15
Deadforty
JSeery;
Yes I have the correct for the pump installed. I saw your attachment to post #3 and am currently trying to work thru checking the gauges to see if possibly I damaged them. Thank for all that good information.
Old 06-11-2021, 07:55 PM   #16
paul2748
paul2748's Avatar
Correct me if I am wrong, but you shouldn't need to connect the CVR to the volt meter
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-12-2021, 11:06 AM   #17
Deadforty
paul2748;
I wired the "Batt" gauge per "19Fordy's" diagram and it works like a charm. I wired from my fuse block (3amp fuse) thru the resistor to the gauge.
Old 06-12-2021, 02:42 PM   #18
19Fordy
19Fordy's Avatar
Read this thread about making 1940 BATT gauge read accurately when converting to 12V.
https://www.fordbarn.com/forum/showt...ford+voltmeter
Old 06-13-2021, 09:47 AM   #19
HD Rider
Once in a while my gauges will quit while going down the road. Jiggle the ignition switch or put a little pressure toward the off position and they are happy again.
HD Rider is offline   Reply With Quote
Old 07-13-2021, 11:22 AM   #20
Deadforty
Well, I finally figured out the problem with my fuel and oil pressure factory gauges. I was under the '40 yesterday hooking up the return oil line for the third time (after replacing the oil sender with the 50# unit), looked up to see a wire that had become disconnected. Wondered, could this be the problem on the nonworking fuel gauge ? Reconnected the wires, crawled out from under the car, reconnected the battery, fired the '40 up and had working oil pressure and fuel gauges !!! Again, many thanks for all the good information and help from the people on this site.
Guess I need to look for the real simple solutions first !!!
