03-23-2021, 09:28 AM | #1 |
zenith 2 carburetor
could the zenith 2 carburetor been an original carburetor on a 1930 model-A ford?
cluck |
03-23-2021, 09:43 AM | #2 | |
Re: zenith 2 carburetor
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
03-23-2021, 09:45 AM | #3 |
The designations Zenith 1, Zenith 2 & Zenith 3 indicate the company that made the carburetor. Zenith 1 is Zenith, Zenith 2 is Holley and Zenith 3 is Ford.
Carburetors with no designation can be Zenith or Holley. It is common for no designation Holley carburetors to have an "H" in the castings. The OEM carburetor on your 1930 car could have been a Zenith 2.
Bob Bidonde |
03-24-2021, 02:34 PM | #4 |
Hello Bob, since we are on the subject of carburetors, I have seen your comments about the secondary well and how it may be restricting flow from the Compensator Jet. I have been rebuilding carbs for my club and would like to know what the symptom would be if there is a problem? I have a bunch of Secondary Wells and they all appear to be the same. The other day I took an awl and in going through the open Compensator Jet, I scratched the side of the well. I was amazed at how high up the scratch is and it is in the large diameter section of the well. I believe you are correct that it is possible to have a restriction through the Compensator Jet. I was thinking of grinding a slot down the side of the Secondary Well to the entrance hole at the bottom. Does this sound like a good idea? Sorry to be so windy, Ed
03-24-2021, 03:23 PM | #5 |
I had a restored Zenith-3 on my Tudor. I went to a MAFCA National meet, and someone stole it off my car in the parking lot, and replaced it! with an unrestored Z-2. I couldn’t figure out why my car was running so rough until I opened the hood. >:-(
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. Last edited by 700rpm; 03-24-2021 at 11:27 PM. |
03-24-2021, 05:05 PM | #6 |
03-24-2021, 08:55 PM | #7 | |
zenith 2 carburetor
Wow. That’s amazing. What some folks will do... Sent from my iPhone using Tapatalk |
03-24-2021, 09:40 PM | #8 |
I have seen 2 or 3 carbs where someone took a Zenith 2 used a Dremel to make it look like a Zenith 3
and passed it off on Ebay as a Zenith 3. Last edited by Benson; 03-27-2021 at 07:41 AM. |
03-26-2021, 09:05 AM | #9 |
Thanks very much for the info.123 are the mags.
03-26-2021, 09:10 AM | #10 |
good to know a zenith 2 could have been on my car. and 1,2,3 are the mugs-cluck
03-27-2021, 12:22 AM | #11 |
"and 1,2,3 are the mugs" Local slang? What is mugs?
I know the voices aren't real but damn they have some good ideas! |
03-27-2021, 01:52 PM | #12 |
Typo for "mfgs"? Kinda same question when he referred to "mags" in the post immediately preceding.
My fingers aren't as nimble as they used to be. JayJay
03-28-2021, 09:37 AM | #13 |
thanks for the info on my Zenith 2 carb. Typo for mugs and mags should have been mfg.
03-28-2021, 09:46 AM | #14 |
Thanks! Mfg didn't even come to mind, I was thinking that I needed to add a new word to my vocabulary.
