05-25-2014, 08:34 PM | #1 |
School Bus ...... Flathead fuel pump
Anyone here, ever use a bus fuel pump ? At one time this was a pump sold by speed shops, for hot rodded flatheads. They are listed in the Ford green book, but not much info. on them.
05-25-2014, 09:37 PM | #2 |
Re: School Bus ...... Flathead fuel pump
Seems like they were pretty common on trucks in Canada in the fifties, I have had one on my '35 2 Ton for a couple years, and it starts right up after sitting all winter. ..B.
05-25-2014, 10:00 PM | #3 |
Well the pump body itself, says made in USA, but on the box it came in, says Canada. thanks for the reply .......Ed
05-25-2014, 10:12 PM | #4 |
I thought the bus pumps were bigger around than what is pictured. A larger diameter diaphragm.
05-26-2014, 12:17 AM | #5 |
05-26-2014, 12:59 PM | #6 | |
Agreed that does not look like the ones i have are bigger I have one on a 4x2 setup and it works great Last edited by lonewolf; 05-26-2014 at 01:27 PM. |
05-26-2014, 04:14 PM | #7 |
The ones I have are the same size as a 55-7 stovebolt v8. The work well but I would caution anyone about using old stock without changing the diaphram cause alky will eat it apart.
05-26-2014, 04:23 PM | #8 |
I guess the ones I spoke of weren't bus pumps then, because the "inverted" top bolts up to a regular 8BA diaphragm and base. ..B.
05-27-2014, 09:20 AM | #9 |
Yes, the one shown there is not a bus pump, which is noticeably larger.
I think what you have is an aftermarket assembly of Ford (normal size) base and a top from some other application. I have seen similar in the chrome gadget section of 1950's speed catalogs...glass dome chromed replacement pumps, just shiny, no higher volume. On the stovebolt connection...I seem to remember that a further high volume enhancement of the bus pump for racing flatheads was the addition of later 1950's Corvette upper casting, which if I remember correctly had six valves rather than two! |
