Old 10-11-2021, 09:25 AM   #1
stude333
stude333's Avatar
Default 1934 pickup windshield swing arm brackets
does any one reproduce the slide arm brackets for 34 ford pickup that mount on the windshield frame? They look similar to the 30/31 model brackets that are available. Can any one advise if the Model A brackets will work. I would appreciate any tips or recommendations.
stude333 is offline   Reply With Quote
Old 10-11-2021, 02:54 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 1934 pickup windshield swing arm brackets
I got mine from Macs
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 10-11-2021, 09:17 PM   #3
34pickup
34pickup's Avatar
My 34 pickup actually has a 31 windshield frame. They are the same except you have to cut off the bottom lip from the Model A frame that slides over the dash. So it also has the sliding arms. Guess that means they are the same too.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 10-12-2021, 03:19 AM   #4
totto
totto's Avatar
The Model A brackets will work. That is what I used when restoring my 1934 pickup.
Henry
totto is offline   Reply With Quote
