06-16-2021, 01:41 PM | #1 |
One Or All 4?
I'm getting some of the desire back to work on old cars......which is good since I just bought this '28 Sport Coupe and it needs engine work. I'm considering doing a compression check, pulling the head and checking things out and dropping the pan to see what's happening in there. The big issues is the supposed rear main leak, burning oil and oil soaked plug in #1. It also runs rough and has exhaust leaks which bother me, but could come later. Anyway, I say all this to ask.....cylinders 2-4 look fine (some soot), but if I'm going to replace the rings on #1 should I also do the others? Or if I don't see signs of oil there would I be ok to skip it? This engine was supposedly rebuilt around 1,000 miles ago.
06-16-2021, 02:10 PM | #2 |
Re: One Or All 4?
Sounds like problems especially for a rebuilt engine with about 1,000 miles. Of course, depends on what "rebuilt" meant to the guy rebuilding it.
Having said that, my experience has been that you should have all four cylinders operating pretty much the same to ensure consistent compression and oil control, not to mention balance. I don't think you can buy a set of rings for just one cylinder anyway so you might as well do a light hone and ring them all. And having said this, the proper way to approach this is to truly assess the condition of your cylinders for wear and taper. The cylinders could be out of round, tapered, who knows what and new rings may slow down but not cure your issue. Also, rear main leaks indicate the need to check the bottom end bearings for condition and clearance. Good luck with it. Most might just say "it needs a rebuild" and it might, but who knows I have nursed some high mileage engines along in the past with a combination of skill and luck. Usually luck! |
06-17-2021, 08:09 AM | #3 |
Re: One Or All 4?
Do not conclude the engine needs rebuilding / overhaul until you have evidence that supports it. Valve guides are a source of oil, and it may be that the rings in Cyl 1 have not seated yet. I suggest that you perform a cylinder leak test.
(1)Remove the valve cover; (2)Rotate the crankshaft so both valves of Cyl 1 are closed; (3)Put the transmission in gear and chock the wheels; (4)Pump 75 psig air into Cyl 1, turn the air supply OFF and observe the gauge. A small amount of leak-down past the rings is normal. Check in the valve chamber for air leakage from the valves and guides.
Bob Bidonde |
06-17-2021, 09:00 AM | #4 | |
Re: One Or All 4?
I would do the same for all four cylinders since you don't know the history of the engine. Do your compression check also. Last edited by Y-Blockhead; 06-17-2021 at 01:32 PM. |
06-17-2021, 09:58 AM | #5 |
Re: One Or All 4?
I'll have to try these things soon. I'm working on the brakes on my old truck and I want to finish that first. So, how do I seat the rings? Why did they just start being this way? Would that cause rough idling?
06-17-2021, 11:37 AM | #6 |
Re: One Or All 4?
06-17-2021, 11:41 AM | #7 | |
Re: One Or All 4?
As best as I can figure, the previous owner rebuilt the engine between 2003 & 2005. So, that's been awhile. Is there some magic formula I can pour down the cylinder to loosen up the rings? |
06-17-2021, 12:07 PM | #8 |
Re: One Or All 4?
I have freed stuck rings, and valves for that matter, with Marvel Mystery Oil, and trans fluid mix. Let it soak for a few days.
06-17-2021, 01:31 PM | #9 |
Re: One Or All 4?
The rings could have been improperly installed or damaged, easy to do with some types of three piece oil rings. Without disassembly you can check the crankshaft for excessive end play, if it moves back and forth much you have bearing trouble and a sure reason for oil to leak past the rear main.
06-17-2021, 02:09 PM | #10 |
Re: One Or All 4?
The thing I don't understand is that the oil burning blue smoke didn't start till days later after I was home. Didn't do that at the dealership. As soon as I can find a helper I'll check that end-play. As I understand it if I push the clutch in the front pulley might (but shouldn't) move forward? Right?
06-17-2021, 02:10 PM | #11 |
Re: One Or All 4?
06-17-2021, 04:01 PM | #12 |
Re: One Or All 4?
As long as you can cover the piston with solvent it will get to the rings, no need to find a specific position. After it soaks for a while and while the plugs are out crank the engine some, you want the oil to leak down out of the combustion chamber before starting it up. Start it outside as it will make a smokescreen!
06-17-2021, 04:16 PM | #13 |
Re: One Or All 4?
Your rear main oil leak may be as simple as too much oil in the crankcase. Wouldn't be the first time it was overfilled. How high is the level on your dip stick.
06-17-2021, 04:19 PM | #14 |
Re: One Or All 4?
CatMan, I would pull the engine to work on it. Taking the head off and the pan off will tell you a lot. You can pull the piston from #1 to look at the rings. It is just much easier to work on an engine out of the car on an engine stand.
06-17-2021, 04:20 PM | #15 | |
Re: One Or All 4?
I'll have to check when I get home. The previous owner said it did leak so he just ran it two quarts low all the time. That makes me nervous..... Also....when checking proper level should I make sure that both ends of the dipstick are securely in the block or does that matter? |
06-17-2021, 04:23 PM | #16 |
Re: One Or All 4?
Push the dipstick fully in. Try a quart less for a while before you rebuild the engine.
06-17-2021, 04:54 PM | #17 |
Re: One Or All 4?
06-17-2021, 08:53 PM | #18 |
Re: One Or All 4?
The oil level is currently halfway between full and low. How many quarts is that thought to be?
06-18-2021, 10:00 AM | #19 |
Re: One Or All 4?
Put any piston 1/2 way up (or down) and they will all be at 1/2 way.
