Old 01-24-2021, 05:07 PM   #1
kwisor
kwisor's Avatar
Default how to remove front hub inner bearing seal?
hello
i have been working on my brakes i am replacing the bearings on the frt. the hub inner bearing seal i can not get it off the backing plate,spindle . what it the best way to remove the old one
thank you
kevin
1930 tudor
kwisor is offline   Reply With Quote
Old 01-24-2021, 06:00 PM   #2
tinkirk
tinkirk's Avatar
Default Re: how to remove front hub inner bearing seal?
Probably really don't need to replace it
Just clean it all up and, you should be good seeing that its just something to keep the dust and dirt out of the bearing.
tinkirk is offline   Reply With Quote
Old 01-25-2021, 12:07 AM   #3
redmodelt
redmodelt's Avatar
Take out the 4 bolts and it should come right off, unless caked with grease and grime then you may need to pry it off.
Old 01-25-2021, 05:12 AM   #4
kwisor
kwisor's Avatar
thanks for the help
kevin
Old 01-25-2021, 07:22 AM   #5
kenparker0703
Clean of all the excess grease adnd dirt , then pry it off with a screwdriver. ken
kenparker0703 is offline   Reply With Quote
Old 01-25-2021, 07:25 AM   #6
kenparker0703
When it goes back on you may have to peen the edges. It should be a tight fit. You do not want that thing rattling loose
Old 01-25-2021, 11:37 AM   #7
kawagumby
kawagumby's Avatar
If the seal isn't rusted in...
After you pull the drum reinstall the nut on the end of the axle, then place the drum over that so the nut will catch the seal, then give it a good pull.
kawagumby is offline   Reply With Quote
Old 01-25-2021, 12:26 PM   #8
katy
katy's Avatar
The seal in't in the hub (drum), it's bolted to the backing plate and spindle.
Actually, it's more of a retainer rather than a seal.
Old 01-25-2021, 12:36 PM   #9
Bob C
After reading this thread I think three different parts have been mentioned
and I'm not sure which one the OP was referring to.
Old 01-25-2021, 05:36 PM   #10
kawagumby
kawagumby's Avatar
What's sad is I just packed the front wheel bearing about a month ago...and I still brain-farted.
To age or not to age, that is the question...LOL.
Old 01-25-2021, 07:37 PM   #11
kwisor
kwisor's Avatar
hello
in bob's photos it is the one on the left
kevin
