10-23-2020, 08:54 AM | #1 |
Banjo pinion removal tool
Found this in a thread on the HAMB.Anyone here tried it this way?
10-23-2020, 08:59 AM | #2 |
Re: Banjo pinion removal tool
Yes, several times.
Sent from my SM-G975U using Tapatalk |
10-23-2020, 09:58 AM | #3 |
I tried it that way with a screw jack as shown in the vern Tardel book and it warped the housing out of round. I ended up buying a cheap hydraulic press and borrowed an exhaust fitting/press tool from local shop to press it out. I then was able to use the press and re shape the housing back round.
10-23-2020, 10:02 AM | #4 | |
10-23-2020, 10:31 AM | #5 |
Back in '67 I changed out a 4.11 to a 3.54 in a '34 banjo.I used an aluminum drift and hammered it out.Worked but don't want to do it again like that.
10-23-2020, 11:20 AM | #6 |
A bottle jack on the inside may work; but you don't want your job to be the time it didn't. |
10-23-2020, 11:43 AM | #7 |
10-23-2020, 01:44 PM | #8 |
Check Ken/Alabama post on thread below
https://www.fordbarn.com/forum/showt...ht=ken+alabama Dave/Green Bay |
10-23-2020, 04:18 PM | #9 |
Heat the housing to 200 degrees and it will come out easily.
10-23-2020, 07:13 PM | #10 |
Yes I have been doing it that way for over 50 years.
10-23-2020, 07:19 PM | #11 | |
Thread Tools | |
Display Modes | |
