05-31-2020, 09:21 AM | #1 |
gear shift extension accessory
Does anyone make the little crooked neck gear shift extension?
06-01-2020, 11:46 AM | #2 |
Re: gear shift extension accessory
We manufacture one that is only for the early model A style brake handle. [email protected] for information. Thanks
06-01-2020, 11:50 AM | #3 |
I’m sorry, misunderstood your request. I saw one of those shifter extensions on eBay last night. It is missing the small fitting at the bottom but pretty easy to make. I have one and love it!
06-02-2020, 07:30 AM | #4 |
Saves cracked knuckles
06-03-2020, 02:20 PM | #5 |
Is this something that clears the instrument panel or gas tank when shifting into second? I have the temperature gauge mounted under speedometer and never had a problem until today.I had a gear shift tower that Snyders rbuilt for me with the reproduction shift lever and it cleared the gauge in second.Trying to figure out why I have trouble shifting to second and third gear I change it out today to a good used one,shifts better still not great but levers must be bent different this one will not fully allow into second because it hits temperature gauge. Either my used one is bent or not bent enough or repro ones,the foreign made chrome ones are bent back at a farther angle.
"Never complain,never explain"... Henry Ford II |
06-03-2020, 04:06 PM | #6 |
"The more things change, the more they stay the same." |
