Old 01-21-2020, 11:33 AM   #1
1936 ford pickup
Default '36 Ford pickup Hood Hinge question....
Hello All,
I have a '36 Ford pickup and trying to put the Hood together.
I have Purchased new the two-piece Hood Center Hinge and both Center Hood Hinge Rod Retainers. Is there a steel rod that goes inside the two-piece Hood Center Hinge and into both of the Center Hood Hinge Rod Retainers.
Bruce....
1936 ford pickup is offline   Reply With Quote
Old 01-21-2020, 01:55 PM   #2
Ideucev8
Default Re: '36 Ford pickup Hood Hinge question....
Hi, not sure about the repro hinges, but the original hinge parts just slide together from the end with no rod.
Phil.
Ideucev8 is offline   Reply With Quote
Old 01-22-2020, 09:33 AM   #3
nelsb01
nelsb01's Avatar
Ideucev8 is correct. the top center pieces are attached together by sliding on side into the other side. The only place a rod is used is attaching the hood side panels.
nelsb01 is offline   Reply With Quote
