10-27-2018, 06:35 PM | #1 |
'34 foam rubber piece
Does the foam rubber pad pictured below go between the top of the steel transmission cover plate and the rubber transmission cover mat? Or, is it sandwiched between the steel transmission cover plate and the top of the transmission? This, on a '34 Sedan....
10-27-2018, 07:00 PM | #2 |
Re: '34 foam rubber piece
The latter.
10-28-2018, 12:15 AM | #3 |
What's that small rectangular slot toward the bottom of the foam piece for? How is that piece oriented? - Round section toward the engine?....
10-28-2018, 06:46 AM | #4 |
The small slot is for the hand brake which will dictate the orientation.
10-28-2018, 02:29 PM | #5 |
DavidG
I see they sell a rubber 'boot' or cover that fits over the top of the shift tower. I've seldom seen the item on restored '33's and '34's. Is this boot factory correct? If so, what is its color?
10-28-2018, 06:40 PM | #6 |
10-28-2018, 07:18 PM | #7 |
Thanks, David, for your enlightenment.....I'm pleased with your responses....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 10-28-2018 at 07:58 PM. |
10-28-2018, 07:51 PM | #8 |
You're welcome!
