Old 09-22-2017, 07:20 PM   #1
Ian in Mississauga
Default Polishing distributor cam
What else besides crocus cloth have you used successfully for polishing old distributor cams?
Ian in Mississauga is offline   Reply With Quote
Old 09-22-2017, 08:10 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Polishing distributor cam
I use a plastic 6inch plastic grinder wheel made for polishing works really good on distributor cams.l
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 09-22-2017, 08:21 PM   #3
KGBnut
KGBnut's Avatar
When I upgraded to a RePop Model B cam I found it was not as smooth as my 80 year old well-worn original. It would eat points blocks. I polished mine on a cloth wheel with a lot of polishing compound. It still not perfect, but it is a lot better.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 09-22-2017, 09:10 PM   #4
Larry Jenkins
Soft cloth wheel and white stainless steel compound block. If it has small scratches an any lobe, buy a new one.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 09-22-2017, 09:55 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I ordered a "B" cam for Minerva, on closer inspection----"OH, she already has one"!---- I traded it off for something?????
Bill Dufus
"THE ASSISTANT GURU OF STUFF"
Old 09-23-2017, 09:30 AM   #6
GPierce
GPierce's Avatar
Bill Stipes' increased dwell precision lobe cam; $12.50
GPierce is offline   Reply With Quote
