03-13-2021, 03:39 PM | #21 |
Re: Inner Tubes for Radials?
That's another reason I felt more comfortable with tubes. Feared with tubeless, I get to the storage garage and find a slow rim leak caused a flat tire. And the fix may not be simply airing-up the tire. If the flat tire bead rolls off the wheel, then I am looking at having to pull the wheel/tire and a trip to a tire shop.
03-13-2021, 06:39 PM | #22 |
Sort of a stupid question, but do they make tube type radial tires? I've never seen them, but they may exist. If there is no tube type radial tires then what are radial tubes made for if not to be run in a tubeless radial tire. So far I've done fine with radial tubes in my tubeless radial tires with Kelsey Hayes true wires.
Stay safe Steve |
03-13-2021, 07:15 PM | #23 | |
Many 16" radials from Coker are listed to require tubes. |
03-13-2021, 07:17 PM | #24 |
Curious if they have the ribs on the inside that would rub a tube?
03-13-2021, 08:53 PM | #25 |
Coker 17 inch Radial Tires for my '34. This, from the Coker Tire Site >
SKU688901 GTIN 00842199101751 Brand Excelsior Product Size 550R17 Tire Construction Bias Look Radial Sidewall Style Blackwall Radial Aspect Ratio 80 Rim Diameter 17 Overall Diameter (in) 28.5 Section Width (in) 5.7 Tread Width 4.60 Rim Width (in) 4.50 - 5.00 Max Load Capacity 1279@41 psi Speed Rating S Load Index 89 Construction Ply 6 PLY POLY/STEEL DOT Approved Yes Tube Type or Tubeless - Tube Type
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 03-13-2021 at 09:00 PM. |
03-13-2021, 10:41 PM | #26 | |
V8 Bob has the straight skinny on the history and purpose of the safety bead on the rims. One of Chrysler's many innovations.
Those who do not move do not die, but are they not already dead? |
03-14-2021, 11:08 AM | #27 |
Ford didn't use safety rims till long after the flathead era. The wheels on my 51 Mercury cars don't have them and they are still riveted. The 5 on 5.5" X 15" wheels for the mid century Mercs use large diameter outy mount hub caps and have a large center hub hole so I'm stuck with them. They have had tubeless tires since the early 70s and do just fine as long as a person slows down for the sharp turns.
03-14-2021, 01:03 PM | #28 |
I have been following this thread with interest, as well as the one recently on driving on 12 year old Coker tires.
https://www.fordbarn.com/forum/showt...ht=coker+tires My current radials are seemingly in good shape but old. That thread got me thinking about replacing them. My 34 fordor currently has aftermarket 15" wire wheels with P225/70R15 tires. These are pretty wide, and I do prefer the look of the more original narrower tires. I don't know how wide the wheels are, but according to tire websites, they must be 7 to 8" wide. I don't have access to my car right now to verify. If I am getting new tires, I was considering changing wheels to stock 17" x 3.25" wide wheels, which I would have to buy and get painted, so this is a fairly major decision. However, I would still want to have radial tires. I have been wondering if I would need to have tubes for these tires. As Petehoovie posted, the Coker tires for these wheels say they are designed to use tubes. I haven't been able to find any tires on line that say they don't require tubes. Are there any radials for 17 x 3.25" wheels that don't require tubes? Does anyone run tubeless radials for 17 x 3.25" wheels? I know there are other issues to consider as well. Would have to compare the diameter of the new standard size tires to the current ones and make sure they would fit, as my car has been lowered somewhat. The narrower tires would fall further inside the wheel wells, so that could help. Would also need to consider the impact on the speedometer. Here is a picture of my current wheels and tires. Still just considering it at this time and trying to get all the facts. Thanks for any input. |
03-14-2021, 04:30 PM | #29 | |
Hopefully, the person will also not need to make an unplanned "sharp turn" at speed to avoid debris in the road or a vehicle pulling out in front of him/her. When the tire bead comes off the rim seat at speed, the rim can dig into the ground and then things get very interesting.
03-19-2021, 07:22 PM | #30 |
After retiring from 35 years in the medium commercial tire business, I can offer some info on tubes.
Radial tubes should have the following benefits over bias tubes: *Heavier gauge rubber *Wider splice overlap *Heavier valve stem base All characteristics to deal with the additional flex inherent in the radial tire’s construction. Tubeless tires are tubeless because the compound of the inner layer of rubber, or liner, resists the migration of air molecules through it, plus they have a slightly tapered 7* bead angle that coincides with the same angle on the rim’s bead seat area. This helps lock the bead to the rim. The tube is merely an air container to prevent air loss through the porous liner. Any penetration (nail) results in instant air loss and the potential for rapid tire deterioration and control issues. The liner of the tubeless tire is designed to close around a penetration and minimize or stop the air loss. The safety bead rolled in to the steel rim helps to keep the tire’s bead from being sucked in to the drop center of the rim under low inflation or high side load, again resulting in loss of stability and control. Farm tubes are not intended for highway use; only slow moving, relatively straight ahead operation at speeds less than 20 mph. They lack every feature of a radial tube. Don’t risk it! Last edited by hotrodA; 03-19-2021 at 07:39 PM. |
03-20-2021, 09:09 PM | #31 |
03-20-2021, 11:43 PM | #32 |
Yoyo, It's been a while since I did it; I've had zero issues since, so I am unable to tell you how much I put in, however the website told me. The filling is the fun part; I followed the instructions on the website, and modified to suit. I used a 'sauce ' bottle; I guess you guys would call it a ketchup bottle; a bottle with a tapered nozzle...I filled the bottle with the required amount of beads. Used a bit of clear plastic tubing of appropriate size to fit over the threaded portion of the valve stem and onto the spout of the sauce bottle. Idea is, remove the valve from the stem, fit the plastic tube onto v/v stem, pour some beads down the tube [you can see them because the plastic tubing is clear], until they've backed up about an inch into the tube, remove bottle, insert a compressed air duster gun over tube and blow the beads into the tire. Repeat until all beads are installed.
Now, I had trouble doing this initially, the beads would back up and refuse to blow into the tube. I figured there's like a flap of rubber at the base of the valve stem that was plugging up the works...I used a drill bit in a drill through the valve stem to clear this obstruction. Worked better after that. Don't drill through the opposite side of the tube!! All in all, the entire operation to fill 5 tubes took around 2 hours. sorry I can't be more concise!
03-20-2021, 11:45 PM | #33 |
When using the air gun to blow the beads in, don't give it a continuous burst, rather a puff, puff, puff, suddenly they'll all just disappear into the tube!
03-21-2021, 03:48 AM | #34 |
Have you tried changing the backs for the fronts and see if they still loose air?
