11-02-2018, 05:02 PM | #1 |
Diamond B i.d.
I know this is unimportant but I'm curious. The engine in my car is a model B. It has the small diamond in the casting but there is no date code. Is this common?
11-02-2018, 11:08 PM | #2 |
Re: Diamond B i.d.
My "A" Diamond block has no date code.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
11-02-2018, 11:44 PM | #3 |
Re: Diamond B i.d.
There is a number stamped on a small plate that is date coded. rv in so can't show picture. But in on block looks like plate with two mall screws but is cast into block.
www.whidbeymodelaclub.com |
11-03-2018, 03:17 AM | #4 |
Re: Diamond B i.d.
Model A diamond blocks did have date bar. I have had two of them.
11-03-2018, 03:48 AM | #5 |
Re: Diamond B i.d.
can you guys show a picture of the date bar location
11-03-2018, 05:35 AM | #6 |
Re: Diamond B i.d.
11-03-2018, 07:59 AM | #7 |
Re: Diamond B i.d.
D126 = April 12th 1936
11-03-2018, 11:07 AM | #8 |
Re: Diamond B i.d.
My car has a diamond engine, not sure what that means. Will look for the date code and do some research on Diamond engines.
Thanks guys Gerry Birch Bay WA |
11-03-2018, 12:19 PM | #9 |
Re: Diamond B i.d.
I have 2 "Diamond" Model "B" engines and neither of them has a date. I see no significance to the "Diamond" blocks other than the "Diamond" caster's mark is indicative of an aftermarket manufacturer.
Bob Bidonde |
