Old 12-08-2012, 10:43 PM   #1
BrianBurkert
BrianBurkert's Avatar
Default Oddball early (?) Holley (?) carburetor
This belongs to a friend of mine. It doesn't seem to be in any of the authoritative carb and restoration books. Can anyone explain it?
He provided these notes:
SALIENT FEATURES:
Upper body marking – H raised*
Lower body marking – H raised*
Throttle plate – unmarked
Venturi dowel pin – steel
Double venturi
Secondary well – integral
GAV seat – brass
Assembly bolt head width – ½ inch
Assembly bolt head thickness – 9/16 inch
Float – 7.16 from hinge to solder line
Bowl vent – none
Idle air vent hole is 9/32 inch *Early Holley manufactured Zenith carburetors body marking letters were indented – later raised markings were from January to June 1929 and accompanied by “Zenith-2” on the float chamber exterior.
(Note: I have some other photos of some of the specific features.)
BrianBurkert is offline   Reply With Quote
Old 12-08-2012, 10:48 PM   #2
BrianBurkert
Default Re: Oddball early (?) Holley (?) carburetor
A couple more photos
Old 12-08-2012, 11:30 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
The bowl vent is the hole closest to the double venturi. Nice looking carb.
Does the choke lever have a hole for a pull wire?
Old 12-08-2012, 11:40 PM   #4
BrianBurkert
Looks to me like the choke lever has a hole for the wire. Some of the external hardware may have been replaced.
Old 12-09-2012, 12:01 AM   #5
BrianBurkert
False alarm. It looks like this carb appears in the Judging Standards, page 1-14 (Rev. 2011). Sorry.
Old 12-09-2012, 11:46 AM   #6
BrianBurkert
My friend noted the lack of the boss under the GAV, as is shown in the photo of the Judging Standards. However, I think under the charts of carburetor features on the previous pages, this carburetor is covered under the Standards as "normal." There just isn't a photo of this particular variation. Anyone attempting to stump the Standards should be prepared to eat crow.
Old 12-09-2012, 11:54 AM   #7
Carb Guy
Carb Guy's Avatar
The choke driver is made of brass which is an after market item, the original on these early carbs was pinned.
Carb Guy is offline   Reply With Quote
Old 12-09-2012, 01:55 PM   #8
frank55a
What you have is NOT an odd ball carb it appears to be a mid 28 Holley double venturi carb. It is a fairly rare 28 Model a carb, made by Holley. While the 28 Model A carbs are generally all referred to as "Zenith" they were really Zenith design and they were made by Zenith and Holley.
frank55a is offline   Reply With Quote
