Old 02-12-2021, 05:05 PM   #1
grumppyoldman
grumppyoldman's Avatar
Default Drivers door latch
Drivers door latch won't hold door closed, just pulls back open. What causes this problem, it's on a 55 Fairlane.
grumppyoldman is offline   Reply With Quote
Old 02-12-2021, 06:46 PM   #2
frank long island
frank long island's Avatar
Default Re: Drivers door latch
if i remember there's a spring that sets the star wheel or something
frank long island is offline   Reply With Quote
Old 02-14-2021, 09:48 PM   #3
miker98038
miker98038's Avatar
It's also possible the plate in the door jamb has drifted out of adjustment. Those 55's were marginal, one of the reasons they used a new deeper design on the 56's. Seems to me there's also some kind of "ratchet" catch in the star wheel as Frank mentioned above.
miker98038 is offline   Reply With Quote
Old 02-15-2021, 04:47 AM   #4
KULTULZ
KULTULZ's Avatar
Question Re: Drivers door latch
There was a lengthy thread regarding this not too long ago. The consensus was to go with the 56 system.
It's in the archives somewhere (just like PREGO) but I have no luck with the SEARCH FEATURE here.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 02-17-2021, 02:26 PM   #5
grumppyoldman
Thanks for the info. as soon as the weather clears up I'll check it out. Al
Old 03-17-2021, 03:10 PM   #6
grumppyoldman
Got it fixed, dropped the latch down and moved it inward, now it stay closed and back edge lines up perfect.
Old 03-18-2021, 09:26 AM   #7
54vicky
54vicky's Avatar
good for you
54vicky is offline   Reply With Quote
Old 03-18-2021, 05:34 PM   #8
Daves55Sedan
Daves55Sedan's Avatar
You mean....you moved the striker plate down and inward?
The best way to adjust a striker plate is to loosen the attaching screws barely enough to allow the striker to move with the force of the door latch closing on it, but not loosening the screws so much that the striker plate falls to the bottom of it's enlarged holes behind it.
The result you want is for the "guide" on the door latch to engage with the striker spring-loaded nylon "push-bar" AND simultaneously having the latch star-wheel engage properly with the teeth on the striker.
I also suggest that the striker plate be moved OUTWARD from the surface of the door-jamb enough so that the latch star-wheel teeth will fully engage with the teeth on the striker plate. This can be accomplished by adding more composite shims behind the striker plate. Don't move it out so far that the door gets scratched by the edge of the striker.
Daves55Sedan is offline   Reply With Quote
Old 03-24-2021, 02:04 PM   #9
grumppyoldman
Thanks got-er-done. Al
