04-13-2023, 02:30 PM | #21 |
Re: Fact or Fiction: Headlight Lens Gasket
So I have cork gaskets from a reliable vendor but trying to put the cork in the reflector isn't working. Anyone have a suggestion on a lubricate (water, oil, ?) to apply to the cork so they'll slip and stay in the reflector groove? Thanks
04-13-2023, 07:09 PM | #22 |
Mine are original silver and never been replated since 1964 since I owned it.
Still look like new! |
04-13-2023, 07:12 PM | #23 |
Forgot to attach photos.
04-13-2023, 09:00 PM | #24 |
Elaborate on what is not working. If it is too loose you can crimp the outer edge some
04-14-2023, 07:58 PM | #25 |
MikeK, I did not know that.
1Crosscut, good to have options. Thanks to both of you. |
04-15-2023, 12:50 AM | #26 |
04-15-2023, 11:42 AM | #27 |
Is the cork square cut or rectangular? I would soak if I had to in hot water. You might ask the vendor if what you have is correct.
04-16-2023, 12:10 PM | #28 |
Thanks, JFrankin, now that I look at them, they are rectangular so problem solved. LRF
