Old 10-04-2020, 07:53 PM   #1
Talkwrench
Talkwrench's Avatar
Default Drive shaft balance?
Has anyone ever balanced their drive shaft? While I have everything apart it just a thought ..
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 10-04-2020, 08:11 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Drive shaft balance?
Open or closed??
If open, yes, after installing a new yoke.
Old 10-04-2020, 08:15 PM   #3
JSeery
JSeery's Avatar
I always balance open driveshafts, but have never done a closed one.
Old 10-04-2020, 09:57 PM   #4
cas3
on model T's we static balance the solid shaft. sometimes they are off quite a bit, and its nice to see them spin true
Old 10-05-2020, 12:00 AM   #5
Talkwrench
Talkwrench's Avatar
No closed, with center bearing .
Old 10-05-2020, 08:09 AM   #6
Kube
Kube's Avatar
I never have. I've never had an issue either.
Old 10-05-2020, 09:05 AM   #7
JSeery
JSeery's Avatar
Because of the small diameter, short of being bent, it shouldn't be an issue.
Old 10-05-2020, 10:34 AM   #8
V8COOPMAN
V8COOPMAN's Avatar
I'd have to concur completely with that thinking....SOLID shaft! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-05-2020, 11:24 AM   #9
rotorwrench
rotorwrench's Avatar
As was already mentioned, the small diameter and the fact that is is solid have a lot to do with whether an imbalance will affect it. The whipping of a solid shaft can be a problem so Ford used a damper like most drive systems with long shafting. A larger tubular shaft has no mass on it's center line due to being hollow and many are welded tube so they are very much affected. Whipping is generally not a problem on shorter hollow tube shafts but longer ones need the added stability under large torque loads. A lot depends on diameter and length.
Old 10-05-2020, 12:26 PM   #10
quik
quik's Avatar
Why do you think you need to balance the driveshaft?
quik is offline   Reply With Quote
Old 10-05-2020, 03:01 PM   #11
Pete
Pete's Avatar
I had one in the balancer once. I did not have a lathe long enough at the time to check it between centers for straight so I laid it in the balancer and rolled it by hand with an indicator on it. It was bent. I straightened it and then spun it just for kicks to see if it was out of balance any. It wasn't.
Old 10-05-2020, 06:49 PM   #12
grumppyoldman
grumppyoldman's Avatar
I would replace the center shaft bearing while you have it apart if you are concerned it might vibrate. Al
grumppyoldman is offline   Reply With Quote
Old 10-05-2020, 06:59 PM   #13
Talkwrench
Talkwrench's Avatar
Not really a matter of needing too, it's more if anyone has looked into it. It is a long shaft that turns hundreds of rpm Im sure they're not perfect.
Pete what was the method you used to straighten the shaft?
I had it in a lathe yesterday just to touch up where the center bearing runs and did notice a bit of a wobble on the uni end, shaft was held in the chuck roughly in the middle.
Old 10-05-2020, 07:45 PM   #14
cmbrucew
cmbrucew's Avatar
If you are good you might straighten it yourself with two knife edged vee stands and a torch. other wise take it to a machine shop with a long lathe.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 10-05-2020, 08:02 PM   #15
Pete
Pete's Avatar
Dial indicate half then turn it around and do the other end. As long as it runs true in the chuck and the tail center runs true, you should be able to check it ok.
I used heat to straighten it. Heat it on the high side and cool quick with a wet rag or if the lathe has coolant use that. DO NOT heat it enough to turn it color. It will usually take several times to get it straight. Be sure to dial it over the whole length.
Old 10-05-2020, 08:20 PM   #16
Talkwrench
Talkwrench's Avatar
Thanks for that!
Old 10-05-2020, 08:24 PM   #17
Talkwrench
Talkwrench's Avatar
done recently
Old 10-06-2020, 12:23 PM   #18
quik
quik's Avatar
Just curious, usually this comes from chasing a vibration. Looks like your trying to eliminate the potential for a vibration.
Old 10-06-2020, 06:55 PM   #19
Talkwrench
Talkwrench's Avatar
Yes just double checking any possibilities.
I did go past a drive shaft balancing place yesterday just to get an opinion. He quite simply said I wont piss in your pocket nothing that can be done that would be worth it.. So thats the end of that..
Old 10-07-2020, 11:13 AM   #20
quik
quik's Avatar
At least he didn't take the job and steal your money.
Good luck!
