09-27-2019, 08:03 AM | #1 |
35 Ford Wont Crank
Have nice restored 1935 Ford coupe, generally easy start & runs well. Gone for two weeks & unable to start on my return. Won't crank (not spinning) despite full charge & 6 to 7 volt output on relatively new Optima battery. Dead. Am looking for step by step possible causes.
Have purchased new starter button & cutout to try. Not opposed to buying starter & having spares on hand but want to be systematic. What is most probable cause? What other steps should I try? My ford Guru suggests giving starter a good knock for possible stuck cummutor brushes. Running when I leave, not running when I return. Thank you. Last edited by Road Journey; 09-27-2019 at 08:32 AM. |
09-27-2019, 08:13 AM | #2 |
Re: 35 Ford Wont Crank
Still not clear from your post here......IS it spinning over or not??? You have referenced the starter a couple of times but not clear as to IF its actually spinning.
09-27-2019, 08:53 AM | #3 |
clean battery terminals ---
use voltmeter to check switch ----move to starter see if voltage there when switch is pushed ---if voltage there look to starter ----perhaps starter jammed--turn on lights, watch if go dim when starter button pushed ---perhaps put in 3rd gear and rock car to see if starter jammed |
09-27-2019, 09:19 AM | #4 |
As Kurt in NJ says, the starter may be jammed in the flywheel. If rocking the car in high gear doesn't free it, hit it (the starter, that is) a couple of times with a hammer. It won't hurt it.
09-27-2019, 09:51 AM | #5 |
You can try jumping straight to the starter with 12v.
09-27-2019, 11:10 AM | #6 |
