Old 09-26-2019, 07:48 PM   #1
corvette8n
corvette8n's Avatar
Default Intake manifold bolt question
I'm missing a few intake manifold bolts on a spare 1940 flathead, are they all the same length?, can I use hardware store replacements?, are they grade 5 or 8. Thanks
Old 09-27-2019, 07:30 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Intake manifold bolt question
You can use hardware store replacements. Grade 5. Measure the depth of each missing hole and you can easily determine what length you need. You can saw longer bolts and make them shorter, if needed. I don't remember if all bolts are the same length but, I think they are.
Old 09-27-2019, 08:05 AM   #3
Seth Swoboda
Seth Swoboda's Avatar
The correct bolts are "thick headed" in variety. if that does not matter to you just use the regular grade 5 bolts as 19Fordy says.
Seth Swoboda is offline   Reply With Quote
Old 09-27-2019, 08:22 AM   #4
19Fordy
19Fordy's Avatar
Just another thought. Don't over torque those bolts. 23-28 ft. lbs max.
Look here:
http://www.vanpeltsales.com/FH_web/f...ecs32-48V8.htm
Old 09-27-2019, 08:59 AM   #5
deuce lover
deuce lover's Avatar
Not all same length.
16, 3/8 X 16 2.25"
4, 3/8 X 16 1.25"
Don't forget the thin flat washers especially if intake is aluminum.
deuce lover is offline   Reply With Quote
Old 09-27-2019, 09:30 AM   #6
corvette8n
corvette8n's Avatar
Thanks guys intake is original '40's, I will print the page from Van Pelts and hang it on my garage wall.
Old 09-27-2019, 09:55 AM   #7
deuce lover
Okay the ones on the extreme ends are the short ones.
