09-26-2019, 06:45 PM | #1 |
Torque
Torque for rear axle nut on 36 ford car???
09-26-2019, 07:04 PM | #2 |
Re: Torque
A Lot! You'll pucker its over 200lbs...
This is what I do. Make sure your taper is clean, no grease or anything between the surfaces [others may go into detail about matching the surfaces] nice clean and square keyway. I only have a torque wrench that goes to 150lbs so I go all the way with that , then go to the next cut in your castle nut. If you can go further than that youre a better man than me.. Good luck!
09-26-2019, 07:35 PM | #3 |
Re: Torque
If you get up to 180 or just north of it, you'll be fine. It can make one a bit nervous to torque something that is as old as it is and not think it'll not strip out.
09-26-2019, 08:48 PM | #4 |
Re: Torque
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
