Old 12-13-2018, 04:15 PM   #1
qmdv
qmdv's Avatar
Default Body height on a 32
I have a stock 32 frame. I bought a Brookville roadster. Put some sticky one body webbing on the frame rail and bolted the body down with shimming to get the doors to work properly. So far so good. Now I am making floor boards and noticed the the top of the K member is pretty much flush with the top of the floor board.
Not sure if the floor board is to be relieved or cut out completely with a sheet metal cover
I would like it close but this after all is a reproduction car with a 59AB block and 39 transmission.
qmdv is offline   Reply With Quote
Old 12-13-2018, 04:26 PM   #2
vulture
vulture's Avatar
Default Re: Body height on a 32
The floor boards are relieved in a number of places
Wanted Roadster Pick up thank you COLOR]
vulture is offline   Reply With Quote
Old 12-13-2018, 04:35 PM   #3
Bruce_MO
Vulture is correct; there are a lot of relieved areas. I made my set years ago using a radial arm saw and a dado blade. It was a fun project.
I have a set of drawings of the boards that I can scan and send you if you want them. PM me if you do. But I’d guess you could google “1932 Ford floorboard drawings” and you’d get something.
Bruce
Bruce_MO is offline   Reply With Quote
Old 12-14-2018, 06:30 AM   #4
Kerk
Try the Nuts & Bolt Guy--Roy N.
Kerk is offline   Reply With Quote
Old 12-14-2018, 07:15 AM   #5
glennpm
glennpm's Avatar
I just checked Roy Nacewicz page and couldn't find the floorboards listed in the latest catalog. They were there a couple of years ago. I would contact him.
http://fordscript.com/
CONTACT
If you have a question please contact [email protected].
Roy Nacewicz Enterprises
fordbolts.com
Tel: (734) 654-9450
P.O. Box 544, Carleton, MI 48117
Check this post by Pete. The first picture shows the bottom relief mentioned above
https://www.fordbarn.com/forum/showp...1&postcount=26
Glenn
Old 12-14-2018, 08:20 AM   #6
DavidG
DavidG's Avatar
They are no longer available from Roy.
