Old 07-21-2020, 10:01 AM   #21
ChuckD
ChuckD's Avatar
Default Re: Block drain for 8RT
Originally Posted by flatjack9 View Post
It is not unusual for that drain hole to get clogged so the water will not drain properly.
Thanks, flatjack9 for the knowledge. It's a great help.
ChuckD is offline   Reply With Quote
Old 07-21-2020, 10:02 AM   #22
ChuckD
ChuckD's Avatar
Originally Posted by JSeery View Post
As Ronnie pointed out, a drain on the radiator is still not going to totally drain the block.
Thanks JSeery, your knowledge is a great help.
Old 07-21-2020, 10:06 AM   #23
ChuckD
ChuckD's Avatar
Originally Posted by Alaska Jim View Post
As Ronnie stated, there is a good flat spot on both sides of the block at the front. I drilled and tapped both sides and installed drain cocks for the eng. in my 51 merc., and the eng. for my 29 roadster project. I did this so I did not have to remove hoses to drain cooling system, in case cooling system maintenance. ( heater hoses, heater control valve, t-stats, even head gaskets.) I did it mostly to be able to completely drain and change out the anti-freeze every couple of years. I will say that it is best done with the eng out of the vehicle. may not be possible in the vehicle
Thanks, Alaska Jim for the input. I will put it in the brain housing group. Mine is a '50 merc block with BA heads. Don't know how you have a lot a cruising time up in the tundra country! But I know any time is great with a flattie!
Old 07-21-2020, 10:09 AM   #24
ChuckD
ChuckD's Avatar
Originally Posted by Ronnieroadster View Post
The 8BA flathead block WILL NOT drain completely even with the lower radiater hose removed. I always drill and tap the 8BA blocks in the same location as the drian on the early blocks. Theres a nice flat area on each side of the block thats the perfect location to add the drain plug.
Thanks a million Ronnie. Great looking rod too!
Old 07-21-2020, 10:11 AM   #25
ChuckD
ChuckD's Avatar
By the way how many gal. does does my '50 flattie hold?
Old 07-21-2020, 02:13 PM   #26
Ronnieroadster
Ronnieroadster's Avatar
Chuck you will find depending on the size of the radiator the capacity will be 4 to 5 gallons.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 07-22-2020, 10:17 AM   #27
ChuckD
ChuckD's Avatar
Ronnieroadster
Thanks again, Ronnie. Didn't know I was in such honored company. Congrats on the salt flat award in 2018. When you get a chance would like to see the car and what you did to the flattie to make it so fast. Thanks again.
Old 07-22-2020, 05:04 PM   #28
Ronnieroadster
How about a ride along as my supercharged 292 cube Flathead powered gas burning rear engine modified roadster hits hits 200 MPH. The second video is from an early test run with a 258 inch engine.
https://www.youtube.com/watch?v=WuRbG60gTpM
https://www.youtube.com/watch?v=Sv_-lQCxHQA
Old 07-23-2020, 10:43 AM   #29
ChuckD
ChuckD's Avatar
Man O man, I can't believe that is a flattie. Holy cow, that shit is wicked sounding in both videos. Were both engines supercharged? I'd love just to get mine to just be a bad ass engine with some umph! What did the 258 post for speed? I could listen to a flattie all day long. There's just something different in the sound of those beautiful engines. Even my single carb merc block, BA heads sounds good. Just don't know enough about em (my first flathead at 70 Y/O) to start building something. I'd insert a photo here, but don't know what a URL is. Thanks again, Awesome!
