Old 11-13-2014, 09:29 AM   #1
BrianBurkert
BrianBurkert's Avatar
Default Model B Cam
A quick question: We opened up a friend's motor and found a Model B cam (fuel pump lobe) inside. As I recall, the Model B cam is directly interchangeable with a Model A cam, right?
BrianBurkert is offline   Reply With Quote
Old 11-13-2014, 09:31 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Model B Cam
Right
Old 11-13-2014, 09:33 AM   #3
BrianBurkert
Thank you!
Old 11-13-2014, 10:47 AM   #4
darrylkmc
darrylkmc's Avatar
Model B cam followers are different than Model A, the solid original ones anyway.
Go to Vince Falters Ford Garage, here is a link to cams and tappets:
http://www.fordgarage.com/pages/camshaftspecs.htm
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 11-13-2014, 02:37 PM   #5
hardtimes
hardtimes's Avatar
Hey Brian,
Yeah, they can be used and have been used as you state.
I'd just be aware that the B lifters were a bit larger (foot) area when using. Maybe whoever installed knew and installed the B lifters also ?
hardtimes is offline   Reply With Quote
Old 11-13-2014, 05:16 PM   #6
rocket1
I wanted to run my model b cam but no body makes the 1.187 tappet,the largest available is 1.125,the last set of a tappets the base wore down rapidly,I don't know if the tappets were inferior or the cam just ate them up. I forgot that Egge machine has 1.140 tappets available,part number f200mb ph# (866) 996-3443
rocket1 is offline   Reply With Quote
Old 11-13-2014, 05:32 PM   #7
Charlie Stephens
I think I would call Bill Stipe of Stipe Machine, stipemachine.com,[email protected], (920) 467-9700. He sells cams with the Model B grind and should have a source for the tappets.
Charlie Stephens
Old 11-13-2014, 06:23 PM   #8
Purdy Swoft
Purdy Swoft's Avatar
I run original model B ,not reground cams in two model A engines and run the single or self locking adjustable lifters from Brattons and Snyders and never a problem . I run reground model A cams ground to Winfield super street 3/4 race grind with the same lifters from Bratton of Snyders and have run these engines for years with good service. You may can find original model B lifters at Berts. Model B lifters are longer and have a larger base
Old 11-13-2014, 07:02 PM   #9
TinCup
TinCup's Avatar
I found a B cam in my diamond block motor. Is this a diamond block?
TinCup is offline   Reply With Quote
Old 11-14-2014, 10:04 AM   #10
1931 flamingo
1931 flamingo's Avatar
Paul
Old 11-14-2014, 10:42 AM   #11
supereal
supereal's Avatar
These is an. Interesting article in one of our trade magazines this month regarding the use of the Model B engines in race cars of the day. The gave the "Offys" plenty of competition. Many had OVH cam head modifications and other exotic changes.
supereal is offline   Reply With Quote
Old 11-14-2014, 12:23 PM   #12
BrianBurkert
TinCup: This is not a diamond block.
Thanks, all, for the info.
