Old 12-20-2021, 10:10 AM   #1
CJStefan
Default Holley 94 accelerator pump tuning
All of my carb rebuilding experience has been on the Rochester B and BC. That's probably the most straightforward carb on the planet, as it has like 15 parts. I'm rebuilding the 94 for for my '49 8ba and I see the accelerator pump bracket has 3 holes on it. Can anybody tell me exactly what moving the C link to a different hole does?
CJStefan is offline   Reply With Quote
Old 12-20-2021, 10:22 AM   #2
1952henry
1952henry's Avatar
Default Re: Holley 94 accelerator pump tuning
Moving link to outer holes shortens or lengthens the throw. Middle hole is the standard setting.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 12-20-2021, 10:28 AM   #3
CJStefan
Mine was set in the middle but why would I want to shorten or lengthen the throw? What would that affect as far as carb operation?
Old 12-20-2021, 10:46 AM   #4
Crankster
Crankster's Avatar
Default Accelerator pump tuning
Climatic conditions
Crankster is offline   Reply With Quote
Old 12-20-2021, 10:55 AM   #5
flatjack9
flatjack9's Avatar
Usually they are marked 1-2-3. I would imagine C stands for co;d and would provide a larger shot. Cold air is denser and so would require more fuel for a correct mixture.
Old 12-20-2021, 11:12 AM   #6
CJStefan
Ahhh so for summer run it in the middle or the lowest setting and for winter run it at the highest? On the 94 would adjusting the mixture screws work the same as moving the c clip? That's how the Rochester was adjusted for temp change
Old 12-20-2021, 11:39 AM   #7
Crankster
Crankster's Avatar
Right. Fuel being heavier than air, it tends to drop out at that moment of acceleration when the butterfly first opens, there will otherwise be a "bog" or hesitation without an extra squirt of fuel to compensate by the accelerator pump circuit, until everything gets caught up. In cold weather this pump shot needs to be richened further.
Old 12-20-2021, 11:45 AM   #8
CJStefan
Is there a general temp range for each setting? With this becoming my daily driver and being in Maryland seeing below zero to above 100, that would be a huge pain to change that setting every time I drive.
Old 12-20-2021, 12:07 PM   #9
JayChicago
JayChicago's Avatar
I would think tweaking down to this degree would be different for each car. Kinda like how much choke to use on start-up. Each engine/carb is a little different. Just have to get to know what your engine likes.
Maybe adjust it in the fall for richer operation, and then re-adjust again in the spring.
Old 12-20-2021, 12:07 PM   #10
ford38v8
ford38v8's Avatar
With the quality of gasoline today, the original seasonal fine tuning of the accelerator pump is usually not an issue unless other factors are involved. I'd set it on the longest (rich) stroke and leave it.
Alan
Old 12-20-2021, 12:15 PM   #11
CJStefan
Would that be furthest left or right? I haven't taken a good look at it yet?
Old 12-20-2021, 12:26 PM   #12
marko39
Per the 39 reference manual the #1 hole (left) is for summer # 2 (center) is for winter and # 3 is for extreme cold temp.
marko39 is offline   Reply With Quote
Old 12-20-2021, 12:30 PM   #13
CJStefan
Sweet thank you sir. Is that info in the green bible as well?
Old 12-20-2021, 12:54 PM   #14
marko39
I have not seen it in that book. Most carbs that you see have arm in middle hole.
Old 12-20-2021, 12:56 PM   #15
CJStefan
Alright thanks for the responses everyone. I truly appreciate it. As of today I'm waiting for a new check ball for the accelerator pump well before I can finish putting the carb together. Damn thing fell out and onto the garage floor never to be seen again
Old 12-20-2021, 03:44 PM   #16
Charlie ny
Middle hole all 12 months....if you need that link e mail and I'll get one off to you pronto.
Charlie ny
[email protected]
Old 01-09-2022, 09:03 PM   #17
CJStefan
Charlie ny
[email protected]
Thank you sir I appreciate that. I have all the parts now. I was in the process of reassembling the carb and i noticed the pump only moves down like a half inch or so. After that the pump rod (not sure of the actual name but the rod that actually moves the pump) continues to move down but the pumps bottomed out. Does that sound right? I know the pump just gets you off idle and I admit I've never paid attention to how much it moves, I just figured it was more than that. I'm holding off on finishing the rebuild until I get this figured out.
Old 01-09-2022, 10:55 PM   #18
ford38v8
ford38v8's Avatar
CJStefan, rebuild kits generally have parts for other carbs included. Accelerator pump rods being one of those, the longer rod is for the 94, I never knew what carb that short rod is for.
In one of your previous posts, you asked if adjusting the mixture screws would be the same as moving the C clip. The answer to that is no, those adjustment screws are for the idle circuit, not related to the accelerator circuit. Your best bet is to read the nomenclature of the 94 carb to understand the functions of the three different circuits and how they function in operation.
Alan
Old 01-11-2022, 09:27 AM   #19
47Monarch
47Monarch's Avatar
Mine is set in the middle the two outer settings are for hot or cold climate.
47Monarch is offline   Reply With Quote
Old 01-11-2022, 10:05 AM   #20
CJStefan
How much does your accelerator pump move?
