Old 03-27-2021, 06:57 PM   #1
CaliforniaBorn36
CaliforniaBorn36's Avatar
Default Electric Wiper switch to replace 1941 Pickup original switch
Is anyone selling an electric wiper switch that looks like and can fit in the same hole as the original switch on a 1941 Ford 1/2 ton Pickup? Does the 1953 - 56 F100 wiper switch fit?
I know many of you have replaced your vacuum wipers with electric, so I am thinking this has to be something someone has done. If you came up with your own home baked solution, what switch did you use and what about the knob?
I'd like a stock look if possible.
Thanks,
CaliforniaBorn36 is offline   Reply With Quote
Old 03-27-2021, 07:08 PM   #2
paul2748
paul2748's Avatar
Default Re: Electric Wiper switch to replace 1941 Pickup original switch
By any chance do you have a New Port Engineering kit? They have an adapter to use the stock knob.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-27-2021, 07:59 PM   #3
CaliforniaBorn36
Nope, mine is a simple single washer, single speed universal motor.
Old 03-28-2021, 01:35 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
In my 40 convertible I used a small pull on/push off switch that fit into the original hole . Made a bezel from the original switch mechanism and put an original type knob on the shaft.
It’s only a single speed motor.
Old 03-28-2021, 07:45 PM   #5
grumppyoldman
grumppyoldman's Avatar
I used the switch that came with my 2 speed wiper kit. I used the antena hole for the switch, it's handy and fills the hole. Al
grumppyoldman is offline   Reply With Quote
