Old 06-17-2020, 02:15 PM   #1
rosenkranswa
rosenkranswa's Avatar
Default Replacing glass in Murray Town Sedan
A couple weeks ago I posted about replacing glass in my '30 Murray Town Sedan and got several good replies. I've now obtained the window glass, a channel kit, and new lower channel. I was getting ready today to start assembling everything and, of course, ran into a snag - so a couple questions before I commit to anything:
1)The Murray left-front lower glass channel I got from Snyders is different from the one that came off of there in that there is a lip on the channel that appears to go to the outside:
Looking at the channel for the Briggs TS, it doesn't seem to have the lip, which matches the one that came off of there.
It almost looks like another seal could go on the lip to seal the window to the door when closed. Looking at the one on the other side, it doesn't seem to have the lip either. I wouldn't be surprised if they just used what they could get when they replaced it quite some time ago - pretty sure its not original.
Is the channel with the lip to the outside correct? and does another seal go on there like the sponge at the top (I have enough sponge to do that)?
2) There was either no adhesive, or traces of very old adhesive on the side channels when it came out of there. I guessing there should be some adhesive on the side channels to keep them in place? A tube came with the channel kit. I know the foam seal at the top gets glued in.
3) There are two rubber blocks with the kit but no indication where they go, any ideas? Also a set of small black screws?
Thanks much for any feedback
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'38 Columbia Girls bike (WWII)
'40 Elgin Boys bike (WWII)
'42 Super Deluxe Tudor
'42 Willys MB Jeep
'43 Willys MBT Trailer
'43 M3A4 Hand Cart
'43 Harley Davidson 42WLA with sidecar
rosenkranswa is offline   Reply With Quote
Old 06-18-2020, 10:12 AM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Replacing glass in Murray Town Sedan
These photos are of my Murray built Victoria, and I am guessing that the window glass parts are similar in design to your car. As for the rubber parts, there are 3 bumpers, the largest of which goes on a bracket that serves as the bottom of travel window stop. On center at the bottom of the window opening in the doors, there are small rubber bumpers that go into slots cut into the door's sheet metal. The small bumpers serve to cushion the glass when the door is slammed.
File Type: jpg 190A RH Window & Door Handle Assembly 672kb.jpg (84.9 KB, 68 views)
Bob Bidonde
Old 06-18-2020, 12:22 PM   #3
jw hash
jw hash's Avatar
Bob I think he is talking a 30 straight window. TS but I could be wrong. they are completely different than the slant widow. the two rubber blocks are the window stops when you roll the window down all the way. and if it is a straight window the lower window setting rubber does NOT have a lip on it like the slant window cars. they have a wiper seal that screws in door.
jw hash is offline   Reply With Quote
Old 06-19-2020, 11:18 AM   #4
rosenkranswa
JW,
You’re right, it is a straight window TS, and your point about the straight window not having the lip is just what I needed to hear. I had decided to clean up the one I took out of there and reuse it rather than go with the new one.
Thanks much guys
Wayne
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'42 Willys MB Jeep
'43 M3A4 Hand Cart
Old 07-01-2020, 10:41 AM   #5
jstone154
I have the same question. I have a Murray Town Sedan '29 and I am also replacing the window glass. I have all of the mechanical parts, but all of the glass and bottom glass supports have been out of the car for a long time and I am trying to put them back. To further complicate the matters, the driver's door is what I think is from a Briggs car. The riser arm doesn't have the extra trough on one side. Which side does the trough go? Outside?
Thanks for the help.
Jim Stone
jstone154 is offline   Reply With Quote
Old 07-01-2020, 01:08 PM   #6
Ruth
Jim Stone
Jim, I believe a Briggs door will not fit in a Murray body, different width.
Ruth
Old 07-01-2020, 01:54 PM   #7
jstone154
Ruth...
Thanks for the info. I was basing my ID on the fact that the two front doors are different. One has a glass mounting rail with no lip and the other one has a lip like the doors in the back. Looking in Model A parts catalogs, the Murrary has a lip and the Briggs do not.
I will try to attach some pictures.
Jim...
Old 07-01-2020, 02:16 PM   #8
Ruth
Ruth...
Jim...
I forgot to add that Murray windows are rounded at the top and Briggs are flat.
Ruth
Old 07-01-2020, 04:06 PM   #9
jstone154
Can anyone tell me what seals the window on the outside when the window is rolled up? Is there some kind of rubber seal? I haven't located on any of the Model A parts catalogs.
Thanks.
Jim Stone
Old 07-02-2020, 07:04 AM   #10
Del in NE Ohio
Del in NE Ohio's Avatar
There was a unique seal that was used on Murray glass channels. I don't think it is being produced. Attached is a note I got from someone when I was restoring my 155-A
Del in NE Ohio is offline   Reply With Quote
Old 07-02-2020, 07:13 AM   #11
Kingo
Wayne,
I’ll shoot a few pictures where the rubber stops go tonight when I get to shop
King
Kingo is offline   Reply With Quote
Old 07-02-2020, 05:23 PM   #12
jstone154
Del...
Thanks for the info. At least I will know what I am looking for.
Jim...
Old 07-02-2020, 06:27 PM   #13
Kingo
The front door has just one attached to the metal brace from latch and riser plat to the wood on bottom of door. The rear doors have two bumpers
File Type: jpeg 5BC04D7A-5576-41D0-8181-B890873AF0B3.jpeg (103.6 KB, 39 views)
File Type: jpeg 27DE91A7-57F1-4268-BB7B-20250E875B00.jpeg (84.7 KB, 35 views)
File Type: jpeg FCD1971F-8972-4C54-8733-5BE7518F6EA4.jpeg (102.7 KB, 36 views)
Old 10-30-2021, 03:53 PM   #14
GT1929
Hello,
Have the glass that came out of doors however with new channels glass wont go in or I cant slide channels in after glass in position. Glass now appears too wide for available gap?
GT1929 is offline   Reply With Quote
Old 11-01-2021, 10:56 AM   #15
JayJay
Post removed - just noticed the thread is over a year old.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
