Old 09-27-2019, 09:45 AM   #1
Sod Buster
Sod Buster's Avatar
Default Extra Parts & Pieces.
I replaced my 47s transmission link rod seals a month ago, went off without a hitch, resealed the side plate, and my annoying leak was cured, tight as a drum.
Yesterday while cleaning my bench I came across a small pin tapered on each end, son of a biscuit eater, I left the pin that goes in the spring too the detent balls out, I have driven the car a few hundred miles with no disaster so far.
I will reinstall the pin, my question is, is there a danger driving the car until I reinstall the pin?
Sod Buster is offline   Reply With Quote
Old 09-27-2019, 09:49 AM   #2
Mart
Mart's Avatar
Default Re: Extra Parts & Pieces.
I'm not sure, but is it the pin that prevents you engaging (for instance) 1st and 3rd at the same time?
If so it would be best to either not use it, or drive it very carefully especially on the 1-2 shift.
Mart.
Old 09-27-2019, 10:52 AM   #3
Sod Buster
Sod Buster's Avatar
Mart.
I am not sure what its purpose is, but yours sounds right.
Would 1st and 3rd together give it overdrive.
Old 09-27-2019, 12:32 PM   #4
19Fordy
19Fordy's Avatar
To Be safe, STOP and put the pins back in. Not worth the gamble.
Old 09-27-2019, 03:13 PM   #5
Mart
Mart's Avatar
Lol no 1st and 3rd doesn't give you 4th!
It would lock the trans solid and could potentially cause a skid. Very dangerous.
