Old 08-23-2016, 03:21 PM   #1
dmsfrr
dmsfrr's Avatar
Default In the fuel line of a '55 T-Bird. What is it?
It's in place of the oem fuel filter but doesn't look familiar to me.
Is it a pressure regulator, fuel filter, ?
Old 08-23-2016, 05:09 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: In the fuel line of a '55 T-Bird. What is it?
It looks like a regulator but I've never seen one like that. If it is it must regulate to a fixed pressure. Most regulators have a dial or some other means of selecting a desired pressure. Does the car have an electric fuel pump? Is there a filter somewhere else in the fuel line?
Dobie Gillis is offline   Reply With Quote
Old 08-23-2016, 05:44 PM   #3
dmsfrr
dmsfrr's Avatar
Pressure regulator.... that was my first guess too. Maybe an after-market one from the 60's.
Looks like it might have an adjustment screw(?) in the top center.
It's on the other side of the country from me, and the photo is the only info I have so far.
The owner isn't sure what it is either.
Old 08-23-2016, 09:00 PM   #4
miker98038
miker98038's Avatar
My first guess would be a regulator, but I suppose it could be filter of some sort, adapted from something else. Someone used to build oil filters that looked a lot like that, but much larger. IIRC, they were a bypass type.
miker98038 is online now   Reply With Quote
Old 08-23-2016, 10:35 PM   #5
aonemarine
aonemarine's Avatar
I don't know. doesn't really look like a regulator. Could it be some sort of pulsation damper? If so then why?
aonemarine is offline   Reply With Quote
Old 08-24-2016, 10:38 AM   #6
Ole Don
Ole Don's Avatar
Please take good care of all the power steering parts, they are getting hard to find. If they need repair, Larres Corp. in Minnesota will fix you right up at a fraction of what it used to cost.
Ole Don is offline   Reply With Quote
Old 08-24-2016, 11:33 AM   #7
GREENBIRD56
GREENBIRD56's Avatar
That is a fuel pressure regulator - and it would be a miracle if the diaphragm was still intact! Even if it is a barn find "survivor" - the crummy alcohol fuel we get would eat it right up........
GREENBIRD56 is offline   Reply With Quote
Old 08-26-2016, 09:48 PM   #8
dmsfrr
dmsfrr's Avatar
The owner said it's coming off the car, for a real fuel filter, likely not to be seen again.
Thanks to everyone for the help.
Old 08-27-2016, 03:28 AM   #9
JeffB2
JeffB2's Avatar
Look for the brand underneath the old vintage Filt-O-Reg units will bring $75-$100 from collectors. If the owner doesn't want it grab it.
JeffB2 is offline   Reply With Quote
Old 08-27-2016, 11:28 AM   #10
dmsfrr
dmsfrr's Avatar
Will do, thanks.
