12-25-2020, 04:35 PM | #1 |
Spark plug socket
Can't seem to find a 15/16" spark pug socket for 3/3" drive. Any ideas?
12-25-2020, 04:45 PM | #2 |
Re: Spark plug socket
That was supposed to be 3/8" drive.
12-25-2020, 05:00 PM | #3 |
I don’t recall... Is the spark plug a 13/16” instead of 15/16”?
Sent from my iPhone using Tapatalk |
12-25-2020, 05:27 PM | #4 |
Maybe just use the spark plug wrench Ford provided, they do work.
12-25-2020, 05:28 PM | #5 |
I use a 15/16" deep socket, ⅜" drive similar to these. https://www.ebay.com/itm/A-CRAFTSMAN...AAAOSwzsNcfqD3
Or use a ⅜" to ½" adapter on a ½" drive socket.
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 12-25-2020 at 05:52 PM. |
12-25-2020, 05:59 PM | #6 |
12-25-2020, 06:04 PM | #7 |
I prefer a 15/16 ring spanner (or 24 mm). Less chance of it slipping sideways and cracking the insulation. Just be careful to not over tighten.
12-25-2020, 06:17 PM | #8 |
Is a ring spanner the same as a box end wrench?
12-26-2020, 09:34 AM | #9 |
The first time I heard the term "spanner" was in a NATO motor pool 50+ years ago. The bloke was holding one in his hand, so I caught on right away what he meant. I suspect "wrench" was just as alien to his ear. -- And a "box" has square corners.
These days we must all be multilingual. |
12-26-2020, 04:27 PM | #10 |
Yes, that is a ring spanner. In English, a wrench is defined as a sudden violent twist or pull. It can be used in a sentence this way: "with a wrench Tony wriggled free"
So, a wrench is the action applied to a spanner, not the spanner itself. It seems to me that this is just one more example of how you guys "developed" your own language when Webster dumbed down the language.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 12-26-2020 at 07:59 PM. Reason: Correct a typo by putting the "r" in wrench. |
12-25-2020, 08:51 PM | #11 |
I use an adjustable wrench on my 3X plugs. One time, it slipped off and hit the adjacent plug, cracking it. I still use the adjustable wrench, but am very careful. At that time, 3X’s were about $25 apiece.
12-26-2020, 08:21 AM | #12 |
Box wrench just to crack loose and snug up. A little never-seize lets them spin right out and back in.
A chunk of rubber tube inside the socket should keep from breaking them. |
12-26-2020, 10:00 AM | #13 |
Don't some Model A spark plugs tank a different size wrench?
12-26-2020, 10:40 AM | #14 |
yes they sell reducers so you can use modern plugs and some older plugs that are subtitutes foe 3x are a smaller size.
12-26-2020, 12:05 PM | #15 |
Yes but he specifically asked about a 15/16" socket, which fits the W-16Y and W-18 Champion. I believe the 3X uses a 1⅛" socket. I don't have one handy to measure.
12-26-2020, 02:19 PM | #16 |
NAPA, AutoZone , etc should have one. Use a 3/8;s extension.
Paul in CT |
12-26-2020, 03:15 PM | #17 |
After I got home, I found I’m using g a Tekton 15/16” spark plug socket. It looks like Home Depot carries them.
https://www.google.com/shopping/prod...:1,prmr:1,cs:1 Sent from my iPhone using Tapatalk |
12-26-2020, 09:28 PM | #18 |
Further to "box wrench" we call hexagonal tube wrenches "box spanners", or some times "tube spanners" because they are made from formed seamless tubing. But tube spanners can also be those open ended spanners used on brake lines etc. So "box spanner" is preferred and quite different from "box wrench"
SAJ in NZ What do do you call each of the above in the USA? |
12-27-2020, 09:49 AM | #19 |
Open end spanners are flare wrenches.
12-27-2020, 09:57 AM | #20 |
I enjoy twisting a wench.
