Old 07-20-2011, 08:32 PM   #1
rogerkb1936
rogerkb1936's Avatar
Default Loose Tank Baffle
The gas tank baffle over the steering column bracket is loose, and causes a very annoying vibration at certain RPM's. I can stop it by pushing up on steering wheel, and no, it is not looseness in the bracket. Anybody know of a quick fix, removing the tank is not an option. Any half-baked solution considered. Thanx.
rogerkb1936 is offline   Reply With Quote
Old 07-20-2011, 09:17 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Loose Tank Baffle
Install the dash rail bracket, then jam some rubber on the upper half of the gas tank bracket to put pressure up on the tank bottom.
Old 07-22-2011, 09:51 AM   #3
JunkOSC
I recall reading on this site about someone using a large magnet.
JunkOSC is offline   Reply With Quote
Old 07-22-2011, 11:04 AM   #4
1931 flamingo
1931 flamingo's Avatar
I was also going to suggest a large magnet. Great minds think alike.
Paul in CT
