Old 12-17-2019, 01:19 PM   #1
marshall k
Default head light socket terminal
Greetings all: I want to repair the head light sockets in my 37 sedan. Can't seem to find a supplier for the light socket wire terminals that contact the bulb terminals that I would use on my own wire. Any Ideas? Thanks for your time.
marshall k is offline   Reply With Quote
Old 12-17-2019, 05:16 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: head light socket terminal
I believe all of the replacement wiring suppliers have them. Most suppliers are happy to assist. Check their web sites. It takes a special crimper to crimp but the wire can be inserted and soldered in place.
Small Brass Button
Price Chart A6
.200 Head Diameter.
.132 Shaft Diameter. Brass.
Old 12-17-2019, 05:33 PM   #3
TJ
TJ's Avatar
For tail light terminals and probably headlamp terminals I have used small tubular rivets and solder wires into the ends. Then use some small shrink tubing to cover the solder joint. Has always worked good for me.
Old 12-18-2019, 10:29 AM   #4
marshall k
Thanks!
