Old 06-18-2014, 03:12 PM   #41
George/Maine
George/Maine's Avatar
Default Re: 35 Ford Brake problems
I realy don,t think you even looked at anything.
George/Maine is offline   Reply With Quote
Old 06-18-2014, 03:31 PM   #42
FlatheadTed
FlatheadTed's Avatar
Going by past discussions on this subject some states allow 12"x90 .This is not a 35 but is a shot of a 34 spindle its a common fix to add a piece of metal on ether side of the of the 34 spindle when fitting the later 39 to 48 backing plates, this is because of the larger holes in the later ones .We changed one spindle for the sake of Govt compliance requirements so we followed along with what was done previously .I would suggest your chatter problem is because the holes in the backing plate are not concentric to the hub .Also people think a change to juice brakes will give them instant good brakes ,not so it depends on a few things one being the type of linings .Also a good thing to add is a remote vacuum booster hidden some were specially if the car is to be driven a lot at high speed . Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-18-2014, 03:36 PM   #43
V8COOPMAN
V8COOPMAN's Avatar
Seems like he doesn't want to take time to take it apart to take a couple of decent pictures. I think the one lousy picture of backing plate shows a '46-'48 spindle, just like the drums. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-18-2014, 05:27 PM   #44
Asphalt Outlaw Hero
Asphalt Outlaw Hero's Avatar
Thanks for comments and suggestions. I've been picking folk's brains as I went. Thanks to people taking time to share, I have a much better idea of my problem.
I like to have a rough idea of what's going on BEFORE I dig in.
I've had several other issues to deal with that have prevented me from dropping the drum again. The car is elsewhere and it is frustrating to get it up in the air and then realize you gotta go back and get something simple. Did I mention it is 95 and in a tin building! I slip in early in the morning and chip at it.
Thanks for everyone's patience.
Asphalt Outlaw Hero is offline   Reply With Quote
Old 06-18-2014, 07:29 PM   #45
Asphalt Outlaw Hero
Spouse's plane was delayed so I got to take advantage of the 88 degree temps :-).
Here's what I found:
Shoe was getting a little gnarly.
Some gauging in drum
Old 06-18-2014, 07:30 PM   #46
Asphalt Outlaw Hero
I couldn't measure ID but I could do the depth
Old 06-18-2014, 07:39 PM   #47
Charlie Stephens
Originally Posted by Asphalt Outlaw Hero View Post
As I understand it, for earlier drums, I'll have to change hubs. I'll need the hubs, then a bearing spacer for the new hub. Regardless, I know I'll need the spacer that goes behind the wheel but IF I can find a decent set of drums, it is simpler than changing out hubs etc.
Hubs are roughly 140 apiece. Drums 125. Pretty soon you're up $600+.Also more to change out and sometimes "fit".
Trying to avoid reinventing the wheel so to speak.
I am not sure what you mean. All you need is the right hubs (early or late) with the drums to make things work. Once they are bolted together they will interchange as an assembly. Note when I say bolted I mean with studs correctly installed with a 20 ton press. My guess is that with a little looking you should be able to find a good hub/drum assembly (less than 12.040) for about $100 (comments anyone?).
Charlie Stephens
Old 06-18-2014, 07:41 PM   #48
Charlie Stephens
Take it to a shop with a drum micrometer. I am not sure what to do with the measurement you are taking.
Charlie Stephens
Old 06-18-2014, 08:07 PM   #49
Asphalt Outlaw Hero
Charlie Stephens
Yeah, I figured it was worthless but too much data is better than none.
Old 06-18-2014, 08:14 PM   #50
Asphalt Outlaw Hero
Charlie Stephens
As I see it then, an option is to install something like some Speedway early Ford hubs along with early style drum ? Or find 46-48 drums, clean up, change bearing and install.
Thanks for hanging in there with me guys.
Old 06-18-2014, 09:14 PM   #51
Mr. Will
Mr. Will's Avatar
I have a good set of drums and hubs just like what you already have. If you are interested PM me.
Mr. Will is offline   Reply With Quote
Old 06-19-2014, 12:19 PM   #52
Charlie Stephens
You left out finding good pre war hub/drum assemblies. Go slow on changing the bearing, a lot of the old bearings are better than the current imports. Clean and repack. Remember not to spin the dry bearing with an air gun or it will damage it.
Charlie Stephens
Old 06-19-2014, 01:17 PM   #53
Asphalt Outlaw Hero
You left out finding good pre-war hub/drum assemblies. Go slow on changing the bearing, a lot of the old bearings are better than the current imports. Clean and repack. Remember not to spin the dry bearing with an air gun or it will damage it.
Charlie Stephens
I should have taken a picture of the Mexico label on the bearings in there now. Oh well ,Fords are made there now anyway ? Many years ago i was spinning a bearing with an air gun and the shop owner explained what was getting ready to happen........
Old 06-19-2014, 01:50 PM   #54
Charlie Stephens
Point well made. You might want to hold off until you buy your used hub/drum assemblies (if that is the way you go) and see if they come with good bearings and races.
Charlie Stephens
Old 06-19-2014, 03:10 PM   #55
Asphalt Outlaw Hero
Most definitely. Bearings have only gotten worse. I pull down new trailers to check to see if they have Russian bearings.
Old 06-21-2014, 10:01 PM   #56
motocycle
Looks to me wheels are only touching drums directly above the stud…..
motocycle is offline   Reply With Quote
Old 06-26-2014, 02:23 PM   #57
Asphalt Outlaw Hero
Saga is over! I found a set of late model brake drums. One was NOS! Turned them and installed new bearings. Knocked old weights off of drums. Drives OK but I'm now trying to find some one who can dynamically balance wheels.
Thanks for all of the assistance I received.
Old 06-27-2014, 12:28 AM   #58
Randy in ca
Randy in ca's Avatar
.......Drives OK but I'm now trying to find some one who can dynamically balance wheels.
While normally not recommended for passenger car tires (due to the low profile/aspect ratio of most these days) balancing beads such as Dyna Beads could be the easiest way to go for high profile tires such as shown in your pictures. Lots of info on the 'net. They are used lots in truck and motorcycle tires - I think the suggested cut off for aspect ratio is suggested as 65, which from your pictures you don't have to worry about. They work great in my bias 600 - 16's.
Randy in ca is offline   Reply With Quote
Old 06-28-2014, 09:54 PM   #59
Asphalt Outlaw Hero
Thanks! I hadn't thought about that.
