Old 06-05-2011, 08:41 AM   #1
calvin amerson
Default transmission
I have heard of some having a 4 sp transmission, sounds like a great idea to me. what tramsmission is used, and any modifications that are neccessary info please
calvin amerson is offline   Reply With Quote
Old 06-05-2011, 09:05 AM   #2
JunkOSC
Default Re: transmission
There are plenty posts on that subject. Not to be rude...but try using the search feature. You will also find a load of info on The HAMB site...again, try using the search tool... it works.
Here is a link to the Banger site on The HAMB....
http://www.jalopyjournal.com/forum/s...d.php?t=161498
JunkOSC is offline   Reply With Quote
Old 06-05-2011, 10:02 AM   #3
ford1
the 4 speed is a truck transmission, first gear is compound low, its almost usless for a car because its so lowed geared that its not practical, if you plan on using the car to pull a trailer up steep hills, or work it in the fields then its what you need, save your time and stick with the 3 speed
thats my storey and im sticking to it
ford1 is offline   Reply With Quote
Old 06-05-2011, 12:46 PM   #4
john in illinois
john in illinois's Avatar
The common 4 speed used in a model A is the ford F 150 trans. made in the 80's. fourth gear is overdrive and it is easier on the engine at 50-55. The first three gears are pretty much the same as the A tranny. I have one in my Tudor.
Several people make kits with the adapters and transmission. I got mine from Dave Delmue. LINK http://modelaonly.com/about_us
At least two other people make kits. They all have good reputations and feedback. The ones that use an AA belhousing like Dave don't require cutting the rear crossmember.
John
john in illinois is offline   Reply With Quote
Old 06-05-2011, 01:04 PM   #5
CarlG
CarlG's Avatar
Just don't get in a hurry with Dave -- I ordered (and paid for) one back in December and still don't have it.
Try Ken Parker [email protected] he is a frequent poster here.
Old 06-06-2011, 11:00 AM   #6
calvin amerson
thanks to all that resopnded some helpful , i have looked at earlier post, nothing there of any use. to JOHN IN ILLINOIS, since the 80's run a 10 year span please be more specific. again thanks to all
Old 06-06-2011, 12:13 PM   #7
john in illinois
I gave you all the general information that I know about the transmission. Hopefully that will guide you in the direction to find specific information.
John
