11-25-2022, 03:19 PM | #1 |
Vintage Tire Gauge Question
Hi all,
Does anyone know how to open one of these to clean and lube? I can’t get the bezel off to get to the dial face. Regards, The Geezer
“Finally driving a car older than me!” |
11-25-2022, 10:24 PM | #2 |
Re: Vintage Tire Gauge Question
Is it a screw on rim? I have a couple but never tried to take apart!
www.whidbeymodelaclub.com |
11-26-2022, 09:02 AM | #3 |
Take it to a watch maker or watch repair shop. There is a special tool that grabs the edge of the bezel all the way around and squeezes it. This compresses the bezel to remove it. There is also a special tool to pull the pointer off and some screws that attach the face plate. If you cannot find a watch maker you may be able to pry the bezel off with a sharp knife, like a #11 Exacto blade, but you stand the chance of damaging the bezel.
Maybe the best thing is to leave it untouched and put it in a display case, then go buy a modern gauge.
11-26-2022, 05:59 PM | #4 |
I finally was able to get the bezel off using an exacto and tapping with a jewelers hammer. It wasn’t a screw-on. Will be cleaning and calibrating it and put it back together like it was originally.
Thanks to all who offered suggestions. This forum is awesome!
11-27-2022, 12:12 AM | #5 |
Pls update us as you work on the gauge….I have a couple of these that I would like to get working again, and will be very interested in following your work.
Thanks - Jim |
11-27-2022, 11:54 AM | #6 |
12-11-2022, 07:30 PM | #7 |
I was able to get the bezel off with a small fine screwdriver. Also removed the 2 screws on the back. Then unscrewed the stem off. You can then wiggle the dial and mechanism out of the case. I took a soft artist paint brush, dipped it in alcohol and “scrubbed” the mechanism being careful not to get alcohol on the dial face (just in case it might smear or kill the printing!). Blew out any dirt or dust with an tire air compressor. I oiled all the pivot points with a very light sewing machine oil. I then put the mechanism back in the case and screwed the stem back on. The bezel was left off at this point. I checked the accuracy on a tire with known pressure. The gauge was off a bit so I popped off the pointer on the dial face after zeroing the pointer. After popping the pointer off I tested the known tire pressure again. I then put the pointer back on pointing at the known pressure. I rechecked a few more times and pressed the. Bezel back on. My Ford tire gauge now works just fine. Hope your repairs/cleaning goes well too!
12-11-2022, 11:18 PM | #8 |
Thanks for the update, and kudos to your success!
12-12-2022, 07:54 AM | #9 |
Any photos taken during the process?
12-12-2022, 09:45 PM | #10 |
No, could have done that, but didn't know it would have been of interest to others.
12-13-2022, 11:27 AM | #11 |
We started with about 130 of these and have rebuilt and restored many over the last couple years. We have 30 remaining and can restore with the model A face, several early ford fantasy faces, and also can do special make autos. U S gauge made at least 25 different faces, as we have that many in our collection.
It does take special tools to open and close a case without damaging or scratching it. Glad to do that for free , but with postage at $5 minimum each trip it gets expensive. Last edited by dropacent; 12-13-2022 at 02:10 PM. |
12-13-2022, 02:09 PM | #12 |
Pics of other US gauges
12-13-2022, 08:48 PM | #13 |
@DropACent - The emphasis on the 35 on the gauge faces answers one question at least..,
01-03-2023, 02:51 PM | #14 |
Hello, who still repair tire gauges, what is the cost? Or can someone post how to fix these?
Thank you Last edited by ford28a; 01-03-2023 at 03:10 PM. Reason: wrong question |
