Old 11-14-2015, 08:09 PM   #1
Larry Jenkins
Default Group 1 batteries - 6 volt for the Model A
How many different ones are offered out there? Source and pricing please?
Larry
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 11-14-2015, 08:33 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Group 1 batteries - 6 volt for the Model A
Fleet Farm probably has the best price. A few years ago they were only about $30, but my friend bought one a few weeks ago and it was now $76.
There are only about 3 companies left in the U.S. that still manufacture batteries.
Old 11-14-2015, 08:50 PM   #3
Larry Jenkins
Thank you, Tom..
Our Blains Farm and Fleet here in Cedar Rapids has one on sale for $39.95 exchange. Their Blain Part Number 040573.
Is this one the same as the one your friend got?
Larry
Old 11-14-2015, 09:24 PM   #4
29er
29er's Avatar
Interstate makes this 1-VHD 6-volt battery:
http://www.interstatebatteries.com/p...964-2147384903
I bought one 3 years ago and it's been reliable. But back then it was $78
Mike in Oregon
29er is offline   Reply With Quote
Old 11-14-2015, 09:41 PM   #5
Mitch//pa
i am a interstate stocking dealer
i have great luck with them
Old 11-14-2015, 09:52 PM   #6
mshmodela
mshmodela's Avatar
http://www.tractorsupply.com/tsc/pro...p?cm_vc=IOPDP1
Specification Description
BCI Group Size: 1
Brand: Exide
Cold Cranking Amps: 625
Cranking Amps: 750
Deep Cycle/Starting: Starting
Product Height: 8-5/8 in.
Product Length: 8-13/16 in.
Product Type: Tractor Batteries
Product Weight: 27 lb.
Product Width: 6-3/4 in.
Reserve Capacity: 160
Terminal Type: SAE
Terminal Voltage: 6 Volt
Warranty: 12-Month Limited
Manufacturer Part Number
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 11-14-2015, 10:04 PM   #7
Beater
Beater's Avatar
I prefer AC delco
Beater is offline   Reply With Quote
Old 11-14-2015, 10:33 PM   #8
Tom Wesenberg
Originally Posted by Larry Jenkins View Post
Thank you, Tom..
Larry
I seem to recall it was made by Exide. That's all I know about it.
Old 11-14-2015, 10:48 PM   #9
Fred K-OR
Fred K-OR's Avatar
Mike in Oregon
I also use interstate batteries in both my Model A's and both of my tractors. Have had very good results. They seem to last a long time even though you don't use the rig every day. But I think I paid around $100 for the last one.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 11-14-2015, 10:59 PM   #10
Mitch//pa
BCI Group Size: 1
Brand: Exide
Cranking Amps: 750
Terminal Type: SAE
interstate is
640 CCA
800 CA
Old 11-14-2015, 11:12 PM   #11
KenCoupe
KenCoupe's Avatar
I have an Optima 6 volt battery. It has been very reliable for me and the car starts up right away even if it has been sitting for a couple of weeks. However, I have read that some people have experienced problems with Optima recently.
KenCoupe is offline   Reply With Quote
Old 11-14-2015, 11:16 PM   #12
Mike V. Florida
Mike V. Florida's Avatar
Ask for a Group 1 battery for 6 volts.
9 1/8 length, 7 1/8 width, 9 3/8 height
6v group 1 batteries are found by the following numbers;
NAPA - BAT 7244
Exide - 7200
Tractor supply - Com 1 HP (part number 0470506) I think.
Autozone - 1-6 volt
Ultrapower #901MF from Deka
interstate part # 1-VHD
Old 11-15-2015, 12:37 AM   #13
Larry Jenkins
Great responses! Thank you!
Does anyone know the length; width and height of the original Model A Ford batteries?
Larry
Old 11-15-2015, 01:15 AM   #14
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Johnson controls makes a good one. Available in the Nw thru les shaub tires.
Old 11-15-2015, 01:57 AM   #15
Mike V. Florida
Larry
Original Ford Battery Dimensions (at bottom):
Width: 7 1/8" to 7 1/4"
Length: 8 7/8" to 9"
Source: Restorer Mar/Apr 1992 Volume 36-6 page 13.
Old 11-15-2015, 08:10 AM   #16
Aok
Aok's Avatar
I have one from NAPA its about 4 years old and still holding charge well.
Aok is offline   Reply With Quote
Old 11-15-2015, 09:03 AM   #17
C26Pinelake
In my opinion the 6volt battery at TSC is the best value. Bought one yesterday for $65.55 out the door, how can you go wrong? Wayne
C26Pinelake is offline   Reply With Quote
Old 11-15-2015, 10:07 AM   #18
leo
leo's Avatar
Why should most of the Tractor Supply battery reviews be negative? As Tom said there are only a few manufacturers making batteries so which one makes the Tractor Supply battery? I find it hard to believe only their battery would be bad.
leo is offline   Reply With Quote
Old 11-15-2015, 10:26 AM   #19
Indiana A. Lover
Send a message via Yahoo to Indiana A. Lover
I have a Tractor Supply 6 volt in my Farmall cub tractor 4 years, works great! Also have one in a 1941 Allis chalmers B it has been in it for 3 years still ok. I keep them in the basement during the winter on a battery tender. Don in Indiana. Larry we have Blains farm and Fleet in Watseka Il.
Indiana A. Lover is offline   Reply With Quote
Old 11-15-2015, 10:42 AM   #20
Tom Wesenberg
I've had real good luck with 6 volt batteries. In fact each one had far outlasted my 12 volt batteries. The one in my Model A came from a recycling yard more than 10 years ago and is doing fine. The Fleet Farm battery in my 1950 Studebaker was given to me as a core battery and is also more than 10 years old and doing fine.
