10-05-2020, 07:44 PM | #1 |
ID motor, think A
Sale I went to, plan on going back and think this is A motor but maybe B?
Power unit with hand clutch & pulley but imagine can use for car. Debate if I want to invest |
10-05-2020, 08:35 PM | #2 |
Re: ID motor, think A
Yes, A motor with governor
Is there a serial number ? |
10-05-2020, 08:42 PM | #3 |
Marvel-Schebler Carb. Model A distributor. Kingston Governor. May be an escapee from a gleaner - but the exhaust is Model A.
It may be a "diamond block." I see evidence of the diamond, but the mark is uncertain/block is dirty. If so lends more credence to original "industrial use." Joe K
Shudda kept the horse. |
10-05-2020, 09:02 PM | #4 | |
10-06-2020, 12:12 PM | #5 |
Haha, First thing I noticed was the Marvel Schebler Carb and the brass top (3X??) spark plugs.
10-05-2020, 09:44 PM | #6 |
10-06-2020, 09:16 AM | #7 |
If you do buy is save that governor maybe worth more than the engine.
10-06-2020, 11:34 AM | #8 |
It's an A. The B didn't have an external oil return line (at least mine doesn't).
10-06-2020, 11:39 AM | #9 | |
I paid $20 for a Pierce at a flea market - and $60 for all the unloader components (which I really wanted AND a Pierce governor.) The diamond blocks have been both touted as better quality, and panned on the reverse account. Perhaps their best recommendation is that they are a "survivor" for the reasons given - and previously a cheap not so worn out replacement engine? My last Model A block I paid $40. The ask price was $50 - but I had to take a big block V8 carcass with it. I negotiated it down to $40 as the V8 had no value to me, and the owner had no other inquiries in a couple of weeks on Craigslist. I have four other engine blocks - all worn out - but can you ever have too many Model A parts? So indeed, given marketing and the fact that vastly more Model A shortblocks are around compared to governors, the statement on pricing is probably true. Joe K
10-22-2020, 04:40 PM | #10 |
Close-up wouldn’t load, but can read A45 499 53
Hand clutch stuck, found a crank & it turned easily considering Temptation to check for spark & oil, twist the tail see what happens |
