01-12-2011, 01:11 PM | #1 |
Riley, George Overhead Valve Heads History Info
Were do you find the history of the great George Riley and the products he made. I have seen a few configurations of the 4 cylinder head and a overhead conversion for a Flathead V-8. Were any other products made by Riley? It seem to be a mystery on information on the products. I have a original Riley 2-Port head and haven't found much about the year produced ,type2 port 4 port and etc.
I see they are making new ones and not much info beside buy one on them as well. Thanks
Wanted flathead speed equipment Thanks |
01-12-2011, 01:20 PM | #2 |
Re: Riley, George Overhead Valve Heads History Info
There is a 260 page book, "George Riley Racing Scrapbook" by Dan Iandola. I found it on flea-bay a few years ago, have also seen it on Amazon.
LINK to book |
01-12-2011, 02:06 PM | #3 |
I think Secrets ran a bit of a story on him as well.
Manuel in Oz |
01-12-2011, 03:07 PM | #4 | |
Thanks for the Link Mike WOWWWW I think 500 bucks for a book is Crazy. I was looking for info on my head not buy another one
01-12-2011, 04:17 PM | #5 |
secrets of speed volume 7 number 4 april 1998
all about the overhead for the bangers i have a copy you can borrow if you like tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information [email protected] |
01-12-2011, 04:48 PM | #6 |
01-12-2011, 06:22 PM | #7 | |
I just found one on Ebay for eighty bucks delivered to my door. http://cgi.ebay.com/ebaymotors/FORD-...Q5fCarQ5fParts
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
01-12-2011, 08:45 PM | #8 |
Riley originally made 3 different 2 port heads B, C, D, D was low compression for trucks, B had higher compression, and on mine, any way, 1 5/8" intake ports. C had 2" ports and was high compression with the 4 port combustion chamber. Early 2 ports had spark plugs on drivers side and were prone to cracking, late had the plugs on the passenger side. As with everything else there are other variations. Dual plug heads for one. Also, each head size had its own size intake manifolds in different configurations to suit the individual, needs up or down, single or dual. The valves and guides were stock model "A" I think C Yapp's 2 port is probably based on a B.
01-12-2011, 09:13 PM | #9 |
So what years did he make them? Also did he make a bunch of them were I don't see alot of originals. So is the 4port a racing head and very cool! With a few winfields hanging off. Now mine must be a late one with plugs on the passenger side. The condition is great on mine and even has bauer flight plugs . Thank you
01-12-2011, 11:16 PM | #10 |
The 4Port was cast iron in the early years then cast in aluminum. There was an iron head with the intakes on top, not on the angled left side mount, I think this was a mid to late 1930's design, had one of these and two normal 4Ports years ago.
01-13-2011, 11:42 AM | #11 | |
01-13-2011, 12:37 PM | #12 |
Riley made as many as 6 different configurations of his 2-port. Yapp copied the early one which in my opinion was the wrong one to copy. The 4-port came out in '33, they and the '34's had huge intake ports, later ones have 1 3/4" ports and run better. Iandola's book is great with lots of info, but it is a scrapbook, not a novel. Riley made a lot of things, a radial outboard motor, a 2 cylinder engine made of Model A parts, a racing side-draft carb and a drone engine for the gov't during WWII which was his monetary downfall, he improved on the military specs and they didn't want that. He made very few aluminum 4-ports but they were made by John Vesco in San Diego and later by George Butler in San Berdo.
01-13-2011, 04:14 PM | #13 |
Back in the '60's during my High School days I always wanted A Riley OHV for my A. Now, thanks to Charlie Yapp I have one.
01-13-2011, 06:11 PM | #14 |
Wow. Talk about disappointment. When I went to http://www.fordgarage.com/pages/1930...alveinhead.htm
posted above I was excited to see the original Riley Installation Instructions. Sadly I found they are blocked so I can't copy them. :-(
01-13-2011, 08:10 PM | #15 |
I, for one, am grateful. Where else would I get this info if you hadn't stuck it up? Yes I'd like to be able to copy it and frame it on my wall, but hey.
Keep the faith Regards Juggs |
01-13-2011, 08:42 PM | #16 |
I don't understand why you would block someone from coping it. Anyone is more than welcome to download anything they want from my web site.
01-13-2011, 08:42 PM | #17 |
I'm impressed that you made it available in the first place. Thanks!
01-13-2011, 09:21 PM | #18 | |
I thank you for letting us enjoy your site and the Riley info. Plus you have lots of info and have help our projects many times!
01-13-2011, 09:28 PM | #19 | ||
Wow them are some very great number. Do you have insert bearing an d counterbalanced crank. I have a fresh motor with new babbit etc and thinking about using the riley head on it. Do you by chance have a photo or specs on the pushrods thanks
01-13-2011, 11:10 PM | #20 |
yeah i forgot i was going to fax those to you today
i'll get on it tomorrow or are you going to be at the shop on saturday? i have to work half a day but i can be down there by 11 or so tk
