09-24-2021, 08:31 PM | #1 |
oil around spark plug
Small amount of oil around spark plug could this be rings or head gasket? around no 3 only
Jimmy Palmer |
09-24-2021, 10:22 PM | #2 |
Re: oil around spark plug
You need to tighten the spark plug a LITTLE bit more or better yet, get a new plug washer. Install the washer with the split side down. It's not rings or head gasket.
09-25-2021, 08:19 AM | #3 |
Spark plug washers do wear out!
09-26-2021, 08:01 PM | #4 |
It was the spark plug gasket! Never had that happen before in 50 years of fooling with antique Fords |
